Tablo dual tuner and stream limit
Hello,
i am using a tablo with 2 tuners along with a couple of M3u's setup for Samsung and Pluto. Is there a way to set a limit of how many shows try to record at once for the tablo? I am not using a docker setup. There may be 3 OTA's shows trying to record at the same time and one will just error out and ill miss it. I do use priority for the different OTA shows but it never tells me that there is a conflict like the tablo app used to do. Is there a way to limit how many channels dvr attempts to record for OTA show's at once?
Does anyone have any suggestions?
Are you using M3U from Tablo if show you can set a limit. If not sorry have no idea.
If you’re using the beta Tablo integration it is already limited to the number of tuners the unit reports to have.
Yes i am using the beta support for table. So if there are 3 shows that are on the same time that are being recorded from the tablo via channels then will it tell me that its not going to recorded the 3rd show or will it just attempt to record it but just be a blank recording or error message?
It will just not even attempt to record the 3RD Show or notify you in the Clients why it was not recorded ... Maybe in the logs it will show if all tuners were in use. Channels DVR does not do conflict resolution.
ok thank you for the info.
