Tablo Help
Will Channels ever have a Tablo setup like HD Homerun?
I don't believe Tablo offers an official, supported API to connect to their devices.
At one time they had an experimental API for the Legacy Tablo, but they discontinued that venture. Still works for me though, as I have both the HDHomeRun and Legacy Tablo as sources to CDVR. Now the new generation Tablo probably not.
As mentioned on this thread, there's no public official API for that device and therefore we can't offer official support for it.
Someone may be able to build a community project utilizing Custom Channels, but we'll never officially support it.
Theres this
Not too sure how well it works since I don't have a tablo but you try to add that to Channels.
You're probably better off with a HDHR if you want to use Channels.
