I have a question.Since tailscale listens for direct connections on port UDP/41641 if I open that port on my router can I direct channels dvr server to direct its connection to that port to almost guarantee a direct connection or will that cause issues?
Maybe that could be the ticket to increase throughput.I can’t do the port forwarding so thought this might be a simple solution.Please let me know if that will work and if it will please test and if works please release a hard coded version,thank you
Opening a port is the same as port forwarding. I don't think you can open ports to Tailscale directly, but you can ask Tailscale support.
