TCM 6039 Via Hulu programs blocked by device ID?
Just curious if anyone else has seen some programs via TVE 6039 (TCMHD via HULU in my case) get blocked with a graphic from TCM that stays up and says "This Movie is not available on this device"?
Note, I had padding before and after and the stream (commercials) were displayed normally before and after the recording.
I have recorded other shows on this channel, but never seen this before. I can tune in live now, and it works as expected.
The show that I tried to record was "MGM Parade" 1955-09-14 this a.m. at 2:29 PST , running for 33 minutes (with padding).
I don't think devs can do anything, so not asking for detailed investigation, but curious if others have seen this on this channel via TVE?
Edit: Adding logs, but there is nothing special noted:
2023/09/28 02:29:00.002416 [DVR] Starting job 1695893340-164 MGM Parade on ch=[6039]
2023/09/28 02:29:02.009063 [TVE] stream timestamps: tcm: start_at=2023-09-28T02:18:44-07:00 end_at=2023-09-28T02:28:40-07:00 live_delay=15.415047391s
2023/09/28 02:29:02.009453 [TNR] Opened connection to TVE-Hulu for ch6039 TCM
2023/09/28 02:29:02.050529 [DVR] Recording for job 1695893340-164 from TVE-Hulu ch6039 into "TV/MGM Parade/MGM Parade 1955-09-14 2023-09-28-0229.mpg" for 31m59.923886984s
2023/09/28 02:29:02.663273 [IDX] Generating video index for job 1695893340-164
2023/09/28 03:01:15.444035 [TNR] Closed connection to TVE-Hulu for ch6039 TCM
2023/09/28 03:01:15.667054 [SNR] Buffer statistics for "TV/MGM Parade/MGM Parade 1955-09-14 2023-09-28-0229.mpg": buf=0% drop=0%
2023/09/28 03:01:15.667168 [SNR] Streaming statistics for "TV/MGM Parade/MGM Parade 1955-09-14 2023-09-28-0229.mpg": timeouts=0 segment_timeouts=0 playlist_timeouts=0
2023/09/28 03:01:16.226068 [MTS] Statistics for "TV/MGM Parade/MGM Parade 1955-09-14 2023-09-28-0229.mpg": discontinuity_detected=0 transport_errors=0 saw_pcr=true saw_pmt=true highest_pts=1950.434600
2023/09/28 03:01:16.257668 [DVR] Finished job 1695893340-164 MGM Parade
2023/09/28 03:01:16.716322 [DVR] Processing file-9234: TV/MGM Parade/MGM Parade 1955-09-14 2023-09-28-0229.mpg
I doubt this has anything to do with your provider. Most likely TCM does not have the rights to stream the film directly over the web, and their license for that program requires it only be offered through traditional/first-party avenues.
(This is similar to the sports blackout notices, I believe.)
Makes sense, thank you!
Yes that's the same message seen on their website which is where the stream comes from
