Telus in canada works?
does telus in canada works?
If you're talking about TVE then no. TVE only works in US. If you're looking to get telus channels on Channels, then you need to pipe it in using CC4C or HDMI/ah4c or adbtuner
I'm not sure if the TVE integration supports it, but you can use a Telus login for the networks where Canada gets mostly simulcasts of the US feed like CNN, Fox News and A&E
Unfortunately the Canadian channels owned by Bell, Rogers and Corus use DRM on all of their TVE streams.
