Tennis Channel TV Everywhere feed out for anyone else?
After a lot of trial and error, I finally for the Chrome Capture for Channels (CC4C) working for Tennis Channel. Below is the configuration that worked for me (including pulling in the EPG data).
I am running CC4C on a spare Windows machine. In terms of configuration, I had to disable some network-level ad blocking and login with my provider, but seems to be pretty smooth sailing since then.
#EXTM3U
#EXTINF:-1 channel-id="TENISHD" tvc-guide-stationid="33395",Tennis HD
chrome://[IP ADDRESS OF DEVICE RUNNING CC4C]:5589/stream?url=https://www.tennischannel.com/en-us/video/on-tv-tennis-channel-tv-broadcast/1641153
This still working for you? Im getting a drm error
This thread is old as hell.
You can't get Tennis Channel with TVE anymore because DRM. Either pipe it in through custom channels (fubo bridge, ah4c/hdmi, adbtuner, cc4c) or use streamlinks
thats what im asking about, the guy who setup a custom channel 3 weeks ago, if it still works for him. I tried it and get a drm error with the custom channel
Still works for me.
You're doing it via tab capture?
You sure you are using TVE ... I do not see Tennis Channels on my XFINITY TVE.... it was removed a while back.
Spectrum still supports as do a few other providers.
Are you watching through TVE in ChannelsDVR ? if so maybe I can get developers to re-add it to XFINITY as I can login to their livetv with XFINITY.
No you can't watch it thru channels it's drmed. I'm trying to use the tab capture for it.
It's like your Local NBC or PBS. You can still watch it from their website, but due to DRM it doesn't work in Channels as a TVE channel.
https://www.tennischannel.com/en-us/page/mps?method=login&source=mvpd
Yeah that is what I thought I have it on my Prime. Anytime I see a post about TVE Everywhere in the Channels Server thread I assume it has to do with Channels DVR TVE not TVE on the web site.
