This is a different issue then. The stream is consistent as far as channels can see so any issues are on the encoding side.
Is it any use to submit other logs then or it's a lost cause?
If you see the same issues on their website https://tennischannel.com/watchnow there's nothing Channels DVR TVE can do to fix it.
Best thing to do is contact them about the issue https://help.tennischanneleverywhere.com/hc/en-us/requests/new
So update on this issue for anyone who cares. Around the beginning of the (2021) year it seems like tennis channel updated their site and this "well be right back issue" in the middle of matches disappeared. So the feed has been good for about 8.5 months, but has once again started having the same problems again in the last few weeks.
So i went and i looked if the tennis channel feed on the website was the having issue. Weirdly, sometimes it is, sometimes its not. Both channels and the feed in the chrome browser sometimes go to the well be right back at the wrong time. But Ive also seen where ONLY channels has the problem, while the feed on the website itself is fine. Sometimes channels gets stuck on well be right back for 10 minutes, while the website runs along smoothly. So im confused here. Ive sent emails to tennis channel support but dont expect much from them. But whats the possible explanation for channels SOMETIMES showing something different than the tennis channel website? Does channels use a different feed? Ive observed the issue on both stable and pre release.
