I would like to test out the strmlnk feature on AppleTV
can i get an invite for the testflight, please.
Id of posted in beta forum but it won't let me post in there.
hi, unfortunately that link is no good to me as I only have the AppleTV and no ios devices
It says at the bottom of the page to email [email protected] if you don't have an iOS device, did you try that?
I guess @maddox or another dev can probably add you from here as well.
Thanks, ive emailed as suggested support.
I followed the invite link but I can't see what I need to do to request an invite link. Should I email [email protected]? I'm looking to get into the iOS version.
You need to follow the link through on your iPhone or iPad. If you don't have one of those, then you need to email support to request access to the TestFlight builds.
Thanks. That worked.
Shortcuts in Channels is just about the coolest thing ever. Thanks devs.
