TestFlight not auto updating Channels beta
Not sure if this is the best place to post this. That said, TestFlight is not auto updating new builds of Channels on any of my Apple TV’s. Not sure if this is a TestFlight bug or something else. Has anyone else run into this and found a solution?
If you open the Testflight app you can make sure the auto-update setting is on.
I should have mentioned that auto update is already turned on. I tried toggling it on/off and even uninstalling/reinstalling the TestFlight app to no avail…
Are you able to manually update?
Yes.
Same here, no updates happen on their own. I have to force a manual update. I have toggled the auto update and restarted the ATV. All 4 of my ATV's have stopped updating.
I’m assuming this is an Apple issue not related to Channels. In any case, I’ve tried to report it to Apple but can’t find a way to do it other than filing a feedback…
You would think that others would be seeing this issue and reporting it. Wonder if I leave the beta test and rejoin if that would fix it?
It’s hard to say but worth a try perhaps…. Please keep us posted.
