This is an ongoing issue
I am spending more time watching live TV in the Hulu
Screenshot 2022-01-30 095550
App than I do channels dvr
2022/01/30 09:51:57.606040 [NAT] Successfully mapped port 8089 using upnp
2022/01/30 09:57:57.082630 [TRS] DNS: OK: Resolved host via system DNS
2022/01/30 09:57:57.576791 [TRS] Cloud Reachable: OK: Connected to community.getchannels.com
2022/01/30 09:57:57.697248 [TRS] Local Time: OK: Local clock is accurate
2022/01/30 09:57:57.768989 [TRS] TV Everywhere: OK
2022/01/30 09:57:57.875934 [TRS] TV Everywhere DNS: OK: Resolved TVE authenticator via system DNS
2022/01/30 09:57:58.338973 [TRS] Remote Access: OK: Successfully established external connection
2022/01/30 09:57:58.941767 [TRS] Disk Permissions: OK
2022/01/30 09:58:02.800489 [DIAG] Could not find file: /vendor/etc/media_codecs.xml: open /vendor/etc/media_codecs.xml: no such file or directory
2022/01/30 09:58:12.606067 New diagnostic log submitted under 76ffee0a-4599-4f39-85b8-8921b35b89e6
Is your shield wired or on WiFi?
What does speedtest app on the shield report
DVR logs don't show an issue.
Please submit logs from the client when it happens, under Settings > Support > Submit Diagnostics > Video Player after it happens
Wired and a little slower than I would expect but still fast enough at 93Mbs
I emailed the number it gave me to your support email
I need you to submit from the TV
Ok I know I sound stupid now, but How do I submit from the tv?
I explained it above:
Of course I just tried an it worked - But it will happen again and I will send it thank you
The diagnostics are to help find the issue, submitting them doesn't actually fix the problem right away.
Submitting them when it is working won't help to solve an intermittent issue.
