Timeline not showing padding?
Watching a show that is being recorded and the time line only shows the actual length of the show and not the 120min pad? It should show 180 min total. Otherwise you can't see if you are about out of buffer.
Is this a regression? I've been noticing this problem recently and I think it used to work as expected.
Is this happening while its still recording or after its fully done too?
I can't confidently answer that question. I'm fairly sure I've seen it with an in-progress recording. But maybe both.
It is still recording. Once the show ends it then shows properly.
Okay will fix for next beta build.
Thanks
The minutes show correctly, but the timeline fill in shows full even though the actual recording is at 150 minutes of a 240 minute recording. I am watching as it is being recorded. The light color purple should be 90 minutes short of being filled in. Thanks
