It works on my desktop, but not on my Apple TV, iPhone, and iPad Pro.
I rescan it and update the latest version.
What channel are you trying to tune? If it works on one client it would typically work for all. I would recommend submitting diagnostics if you haven’t already.
All the channels are like that. I just submit diagnostics.
Are you running a DNS-based ad blocker?
Nope.
If you find something that leads to Pi-hole being an issue then please let me know. I'm the co-creator of it and I run both Channels and Pi-hole locally and haven't had any issues. I want to make sure we aren't the source of problems.
I run AdGuard Home with several extensive block lists, and have not had any issues with Channels DVR.
OP needs to provide more information.
Sorry, I’m not a tech person. So, I have no idea what is DNS and Pi-hole Any way that I should do to fix it? All I did is I uninstall channels DVR server on my laptop and install it on desktop that’s all. Then all the shows are not playing.
Your desktop must have some kind of firewall which is causing it not to be able to stream
Oh ok, i think i how to disable firewall, I’ll update soon. Thanks
