I’m not certain if Channels is causing this but every few days for the past few weeks, the top row on my ATV4K 2nd gen gets stuck and only displays Channels even when I navigate off the Cannels app onto other apps. I think the top row is continuing to update the Channels shows in the top row and Channels works fine. It’s like Channels isn’t giving up control of the top row when I navigate to another app. The only way I’ve found to fix it is to restart the ATV. Killing apps doesn’t solve the issue. After restarting it works for a while then happens again. Anyone else experiencing this behavior?
Sounds like a system bug. There’s nothing we could do to cause that as the system is responsible for the top shelf.
