No luck with Top Shelf on ATV. Anyone have a solution? Thanks
I have to restart pretty regularly to fix the channels top shelf, almost every day or two. All other apps work fine but channels is always a little unstable. Once you restart the Apple TV, open the app, return back to the Home Screen and it should work.
Same issue on ATV 4.5.2, only the restart -> open app -> return to home screen doesn't work.
