Noticed that the Top Shelf is empty in the latest Channels tvOS DVR alpha even though I have channels favorited.
This is a known bug that started with the latest tvOS. Hope to fix it soon.
Is this still broken?
Yes, still broken for me. Just see the pretty Channels splash screen.
Today’s update should fix this.
Working today for me. It has not worked for a while.
Since SD is now using Gracenote and you support Gracenote which one should be select? I am currently using SD I think,
SD guide source is preferred, but if you’re using DVR it doesn’t matter because the data comes from the DVR server.
Just checked this morning and it’s still showing the splash screen.
Channels Version - 1.10.522
tvOS - 10.1.1 (14U711)
I have one ATV where top shelf works, one where it doesn’t. I’ve rebooted the one where it doesn’t; running latest software, still doesn’t work.
Updated the App Store version on the 2nd ATV… seems to not work on that TV now either…
