Seems fine with the beta but the App Store version won’t show the top shelf.
I’ve tried closing the app, restarting the Apple TV. Any ideas?
Thanks
Thanks
Likely a bug, we made some major improvements to the top shelf code in beta so this should be fixed with the next version.
In the mean time the only thing you can try is to reboot the ATV. Restarting the app has no effect on the Top Shelf, since it’s completely separate.
Thanks. It’s weird, it works fine on our second Apple TV but not on the main one!
No urgency though, I’m happy to wait for a fix, I tend to use the beta anyway.
