In the latest beta my top shelf isn’t showing the channels anymore!
Hmm, must be related to “EPG from Gracenote”. IIRC you’re using that right?
Recommend you switch to “EPG from SD” after their recent guide provider upgrade.
Yeah I’m using gracenote. How do I switch?
Click and hold on hdhomerun via Settings tab.
I am also not getting the top shelf in the latest beta (as of Feb 16). I just submitted guide and other logs. I had this issue a while back and I think it was an issue with the guide data. I am set to SD I believe.
There was a bug in the beta but it got fixed before the App Store release today.
