Totally Turtles - Pluto TV not working?
Anyone else having problems with a season pass/record all not working on totally turtles?
it records one and stops. other channels like the barker era work fine.
First guess would be that all the episodes have the same episode ID. So that would be a guide data issue. If that’s the case Channels will only record one because the others are considered duplicates. I think it’s a tricky issue to work around. I think doing a manual recording may be the only option.
hmm, I just tried to do a manual recording, and yep, that would seem to b e the issue. ALL of them are set to record again.
If you look at each airing, it uses the same generic Description and Original Air Date.
There are no Season or Episodes and the ProgramID(Should be unique) is the same for each airing.
