The transcoder is failing for me when trying to watch HD recordings. I'm using the 'classic' transcoder, but also fails with the new transcoder. SD recordings, and HD/SD live TV all work fine. Transcoder is set to 576p @ 2mbps, but changing that doesn't make a difference either. Here is an excerpt from the log:
Log
2019/08/24 16:06:30 [HLS] Starting transcoder for file2651-ip192.168.1.1---2000-576-0-software-linear-false-false-1 at 0s from 192.168.1.1 (encoder=libx264, resolution=576, deinterlacer=linear, bitrate=2000)
[h264 @ 0000000001271a80] SPS unavailable in decode_picture_timing
Last message repeated 45 times
[h264 @ 0000000001271a80] mmco: unref short failure
Last message repeated 1 times
[mpegts @ 000000000124bf80] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 000000000124bf80] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 000000000124bf80] start time for stream 6 is not set in estimate_timings_from_pts
[mpegts @ 000000000124bf80] start time for stream 7 is not set in estimate_timings_from_pts
[mpegts @ 000000000124bf80] Dropped corrupted packet (stream = 1)
[aac_latm @ 00000000030fbd40] frame length mismatch 1552 << 8443
Error while decoding stream #0:2: Invalid data found when processing input
[h264 @ 000000000132e440] co located POCs unavailable
[h264 @ 000000000132b240] reference picture missing during reorder
[h264 @ 000000000132b240] Missing reference picture, default is 65356
[h264 @ 0000000001327b80] reference picture missing during reorder
[h264 @ 0000000001327b80] Missing reference picture, default is 65372
[h264 @ 000000000132b240] mmco: unref short failure
[aac_latm @ 00000000030fbd40] frame length mismatch 1672 << 8419
[aac_latm @ 00000000030fbd40] frame length mismatch 1656 << 8451
[aac_latm @ 00000000030fbd40] frame length mismatch 1544 << 8283
[aac_latm @ 00000000030fbd40] frame length mismatch 1624 << 8507
[aac_latm @ 00000000030fbd40] frame length mismatch 1672 << 8691
[aac_latm @ 00000000030fbd40] frame length mismatch 1608 << 8459
[aac_latm @ 00000000030fbd40] frame length mismatch 1560 << 8331
[aac_latm @ 00000000030fbd40] frame length mismatch 1608 << 8475
[aac_latm @ 00000000030fbd40] frame length mismatch 1648 << 8491
[aac_latm @ 00000000030fbd40] frame length mismatch 1616 << 8435
[aac_latm @ 00000000030fbd40] frame length mismatch 1624 << 8547
[aac_latm @ 00000000030fbd40] frame length mismatch 1576 << 8339
[aac_latm @ 00000000030fbd40] frame length mismatch 1632 << 8515
[aac_latm @ 00000000030fbd40] frame length mismatch 1600 << 8379
[aac_latm @ 00000000030fbd40] frame length mismatch 1552 << 8507
[aac_latm @ 00000000030fbd40] frame length mismatch 1552 << 8483
[aac_latm @ 00000000030fbd40] frame length mismatch 1608 << 8435
[aac_latm @ 00000000030fbd40] frame length mismatch 1600 << 8475
[aac_latm @ 00000000030fbd40] frame length mismatch 1624 << 8603
[aac_latm @ 00000000030fbd40] frame length mismatch 1608 << 8339
[aac_latm @ 00000000030fbd40] frame length mismatch 1592 << 7051
Too many packets buffered for output stream 0:1.
[aac @ 0000000001326dc0] 2 frames left in the queue on closing
2019/08/24 16:06:38 [HLS] Stopping transcoder session file2651-ip192.168.1.1---2000-576-0-software-linear-false-false-1 (view: 0s, out: 1µs, finished: true)
