Transcoding 4K using hardware(vaapi) fails
Hi,
When I try to play 4k(2k videos play fine) videos using the VAAPI hardware for transcoding I get this error:
2022/08/29 01:47:53.422378 [ENC] Starting encoder for Movie.mkv in /shares/DVR/Streaming/file1483-1b0c1588b8fe-2603432460/encoder-7-1235532246 at 7 (6.006000) (encoder=h264_vaapi, resolution=1080, deinterlacer=hardware, bitrate=9744, segment_size=0.01)
2022/08/29 01:47:53.645032 [HLS] ffmpeg: file1483-1b0c1588b8fe: [h264_vaapi @ 0x6a61880] No usable encoding profile found.
Running Channels via Docker on Ubuntu 20.04
/dev/dri is exposed and available to Channels.
I can successfully hardware transcode the file in both Plex and Emby.
Any suggestions?
Try deinterlacer linear
That did it. Thanks!
