I have a QNAP TS-431K with 4 cores(cortex-A15) and 1gb RAM
Transcoding on default H.264 does not work at all in the browser
Turn on HEVC(H.265) in advanced and browser transcoding works perfectly but remote viewing does not even attempt to transcode it presents a message that my NAS is too weak.
Edit: remote play is on Apple TV
Can we get a setting to disable transcoding?
Can we get the remote hardware restriction removed or adjusted for low end hardware like mine that works fine in the browser on HEVC and it will work fine for remote sessions too?
Thank you devs.
