Transcoding problem with Nvidia 1050
I saw in a closed post that the problem with transcoding on Nvidia 10xx series graphics cards is being worked on.
Specifically, I am unable to play 4K videos on a Fire 10 tablet.
Is there any way to get a time frame on when this issue will be fixed.
  • Thanks
What is the error in the dvr logs?
http://127.0.0.1:8089/admin/log
2025/01/06 10:26:44.428060 [ENC] Encoder stopped for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-28-2026344160 after starting from 28 without encoding any segments. Marked segment as failed.
2025/01/06 10:26:44.428060 [ENC] Next segment to pre-encode of 29 is 11.136000001s from the last request of 24
2025/01/06 10:26:44.433595 [ENC] Starting encoder for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-29-2509650371 at 29 (113.780000) (encoder=h264_nvenc, codec=h264, acodec=copy, resolution=576, deinterlacer=blend, bitrate=1000, segment_size=0.01)
2025/01/06 10:26:45.444672 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 000001ff0fcf9fc0] 10 bit encode not supported
2025/01/06 10:26:45.467463 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 000001ff0fcf9fc0] No capable devices found
2025/01/06 10:26:45.467505 [HLS] ffmpeg: file11-ip10.0.0.36:  Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
2025/01/06 10:26:45.622402 [ENC] Encoder stopped for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-29-2509650371 after starting from 29 without encoding any segments
2025/01/06 10:26:45.623342 [ENC] Next segment to pre-encode of 29 is 11.136000001s from the last request of 24
2025/01/06 10:26:45.632571 [ENC] Starting encoder for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-29-2256558537 at 29 (113.780000) (encoder=h264_nvenc, codec=h264, acodec=copy, resolution=576, deinterlacer=blend, bitrate=1000, segment_size=0.01)
2025/01/06 10:26:46.668909 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 000001fc837ed280] 10 bit encode not supported
2025/01/06 10:26:46.699228 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 000001fc837ed280] No capable devices found
2025/01/06 10:26:46.699228 [HLS] ffmpeg: file11-ip10.0.0.36:  Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
2025/01/06 10:26:46.829734 [ENC] Encoder stopped for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-29-2256558537 after starting from 29 without encoding any segments. Marked segment as failed.
2025/01/06 10:26:46.829734 [ENC] Next segment to pre-encode of 30 is 13.638000001s from the last request of 24
2025/01/06 10:26:46.835043 [ENC] Starting encoder for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-30-4143444033 at 30 (115.741000) (encoder=h264_nvenc, codec=h264, acodec=copy, resolution=576, deinterlacer=blend, bitrate=1000, segment_size=0.01)
2025/01/06 10:26:48.354939 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 0000019eed411ec0] 10 bit encode not supported
2025/01/06 10:26:48.378098 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 0000019eed411ec0] No capable devices found
2025/01/06 10:26:48.378098 [HLS] ffmpeg: file11-ip10.0.0.36:  Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
2025/01/06 10:26:48.623195 [ENC] Encoder stopped for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-30-4143444033 after starting from 30 without encoding any segments
2025/01/06 10:26:48.623435 [ENC] Next segment to pre-encode of 30 is 13.638000001s from the last request of 24
2025/01/06 10:26:48.633005 [ENC] Starting encoder for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-30-2914640543 at 30 (115.741000) (encoder=h264_nvenc, codec=h264, acodec=copy, resolution=576, deinterlacer=blend, bitrate=1000, segment_size=0.01)
2025/01/06 10:26:50.057430 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 00000115c23944c0] 10 bit encode not supported
2025/01/06 10:26:50.077343 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 00000115c23944c0] No capable devices found
2025/01/06 10:26:50.077343 [HLS] ffmpeg: file11-ip10.0.0.36:  Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
2025/01/06 10:26:50.228706 [ENC] Encoder stopped for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-30-2914640543 after starting from 30 without encoding any segments. Marked segment as failed.
2025/01/06 10:26:50.228706 [ENC] Next segment to pre-encode of 31 is 15.974000001s from the last request of 24
2025/01/06 10:26:50.235083 [ENC] Starting encoder for Tigers.2160p.4K.x265.10bit.AAC5.1.mkv in D:\channels-data\Streaming\file11-ip10.0.0.36-6415012\encoder-31-4031580706 at 31 (118.243000) (encoder=h264_nvenc, codec=h264, acodec=copy, resolution=576, deinterlacer=blend, bitrate=1000, segment_size=0.01)
2025/01/06 10:26:51.673167 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 000001963d6dc100] 10 bit encode not supported
2025/01/06 10:26:51.695157 [HLS] ffmpeg: file11-ip10.0.0.36:  [h264_nvenc @ 000001963d6dc100] No capable devices found
2025/01/06 10:26:51.695157 [HLS] ffmpeg: file11-ip10.0.0.36:  Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
This is what I see under Channel DVR Advanced Settings
Transcoder -> Gear icon -> View Debug Info
Hardware Transcoder Probe
×Close
h264_amf
[Parsed_color_0 @ 000001dc887779c0] size:640x480 rate:25/1 duration:-1.000000 sar:1/1
Input #0, lavfi, from 'color=black:640x480':
  Stream #0:0: Video: rawvideo, 1 reference frame (I420 / 0x30323449), yuv420p, 640x480 [SAR 1:1 DAR 4:3], 25 tbr, 25 tbn
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_amf))
[graph 0 input from stream 0:0 @ 000001dc887f1600] w:640 h:480 pixfmt:yuv420p tb:1/25 fr:25/1 sar:1/1
[h264_amf @ 000001dc887f2cc0] DLL amfrt64.dll failed to open
Conversion failed!
exit status 1
h264_nvenc
[Parsed_color_0 @ 000002543cbc7a40] size:640x480 rate:25/1 duration:-1.000000 sar:1/1
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_nvenc))
[graph 0 input from stream 0:0 @ 000002543cc407c0] w:640 h:480 pixfmt:yuv420p tb:1/25 fr:25/1 sar:1/1
[h264_nvenc @ 000002543cc41600] Loaded Nvenc version 12.2
[h264_nvenc @ 000002543cc41600] Nvenc initialized successfully
[h264_nvenc @ 000002543cc41600] 1 CUDA capable devices found
[h264_nvenc @ 000002543cc41600] [ GPU #0 - < NVIDIA GeForce GTX 1050 Ti > has Compute SM 6.1 ]
[h264_nvenc @ 000002543cc41600] supports NVENC
Output #0, null, to 'nul':
  Metadata:
    encoder         : Lavf59.16.100
  Stream #0:0: Video: h264 (High), 1 reference frame, yuv420p(progressive), 640x480 (0x0) [SAR 1:1 DAR 4:3], q=2-31, 400 kb/s, 25 fps, 25 tbn
    Metadata:
      encoder         : Lavc59.18.100 h264_nvenc
    Side data:
      cpb: bitrate max/min/avg: 600000/0/400000 buffer size: 800000 vbv_delay: N/A
No more output streams to write to, finishing.
frame=    3 fps=0.0 q=23.0 Lsize=N/A time=00:00:00.00 bitrate=N/A speed=   0x
video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Input file #0 (color=black:640x480):
  Input stream #0:0 (video): 4 packets read (1843200 bytes); 4 frames decoded;
  Total: 4 packets (1843200 bytes) demuxed
Output file #0 (nul):
  Output stream #0:0 (video): 3 frames encoded; 3 packets muxed (237 bytes);
  Total: 3 packets (237 bytes) muxed
[h264_nvenc @ 000002543cc41600] Nvenc unloaded
success!
These types of videos cannot be transcoded. I would recommend you watch them without transcoding.
All of my 4K movies playback fine using Emby server with the Emby Fire tablet app. Hardware transcoding works fine with my server using about 20%~25% CPU.
I also re-installed Plex on my server. All of my 4K movies play fine using Plex server with the Plex Fire tablet app. Hardware transcoding works great with my server using about 10% CPU.
When I try to play 4K movies on the Channels server using the Channels Fire tablet app NONE of my 4K movies will play back. Server CPU utilization bounces from 99% to 50%.
It doesn't seem to be a problem with my hardware. I recently installed Channels DVR so I don't have any weird setups.
Is there something that I am doing wrong? I don't get it.
When plex is transcoding, can you run this command in powershell and paste the output back:
Get-WmiObject Win32_Process | select commandline | Select-String -Pattern "Transcoder"
or this during emby transcoding:
Get-WmiObject Win32_Process | select commandline | Select-String -Pattern "ffmpeg"
Plex
Version 1.41.3.9314
Server CPU Utilization bounces from around 5% to 10%
Playback on the Fire 10 tablet is very good
PS C:\Users\Capt> Get-WmiObject Win32_Process | select commandline | Select-String -Pattern "Transcoder"
@{commandline="C:\Program Files\Plex\Plex Media Server\Plex Transcoder.exe" -codec:0 hevc -hwaccel:0 nvdec
-hwaccel_fallback_threshold:0 10 -threads:0 1 -hwaccel_output_format:0 cuda -hwaccel_device:0 cuda -codec:1 aac -ss
792 -analyzeduration 20000000 -probesize 20000000 -i
D:\media\movies\Tigers.2160p.4K.WEB.x265.10bit.AAC5.1.mkv -filter_complex
[0:0]hwupload[0];[0]scale_cuda=w=1920:h=1080:format=nv12[1] -map [1] -codec:0 h264_nvenc -b:0 15552k -maxrate:0 20736k
-bufsize:0 41472k -forced-idr:0 1 -r:0 23.975999999999999 -force_key_frames:0 expr:gte(t,n_forced*1) -filter_complex
"[0:1] aresample=async=1:ochl='5.1':rematrix_maxval=0.000000dB:osr=48000[2]" -map [2] -codec:1 libopus -b:1 768k
-segment_format matroska -f ssegment -individual_header_trailer 0 -flags +global_header -segment_header_filename
header -segment_time 1 -segment_start_number 792 -segment_copyts 1 -segment_time_delta 0.0625 -segment_list http://127.
0.0.1:32400/video/:/transcode/session/c0c89ea0a50331b3-com-plexapp-android/cb0d1a3d-edc6-412e-aaad-2c4a4131c601/manifes
t?X-Plex-Http-Pipeline=infinite -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1
-segment_list_unfinished 1 -segment_format_options strip_dovi=1:output_ts_offset=10 -max_delay 5000000
-avoid_negative_ts disabled -map_metadata:g -1 -map_metadata:c -1 -map_chapters -1 media-%05d.ts -start_at_zero
-copyts -init_hw_device cuda=cuda:luid:00000000_000079f4 -filter_hw_device cuda -y -nostats -loglevel quiet
-loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/c0c89ea0a50331b3-com-plexapp-android
/cb0d1a3d-edc6-412e-aaad-2c4a4131c601/progress}
Emby
Version 4.8.10.0
Server CPU Utilization bounces from around 20% to 50%
Playback on the Fire 10 tablet is good
PS C:\Users\Capt> Get-WmiObject Win32_Process | select commandline | Select-String -Pattern "ffmpeg"
@{commandline="C:\Users\Capt\AppData\Roaming\Emby-Server\system\ffmpeg.exe" -loglevel +timing -y -print_graphs_file
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\logs\ffmpeg-transcode-96b8baa4-9609-4077-bc19-adab33dc0136_1g
raph.txt" -copyts -start_at_zero -init_hw_device "cuda=cuda:0" -f matroska,webm -ss 00:05:24.000 -c:v:0 hevc
-threads:v:0 1 -hwaccel:v:0 cuda -hwaccel_output_format:v:0 cuda -noautorotate -i
"D:\media\movies\Tigers.2160p.4K.WEB.x265.10bit.AAC5.1.mkv" -filter_complex
"[0:0]scale_cuda@f1=w=1920:h=1080:format=yuv420p,setsar@f2=sar=sar[f2_out0]" -map [f2_out0] -map 0:1 -sn -c:v:0
h264_nvenc -b:v:0 9583088 -g:v:0 72 -maxrate:v:0 9583088 -bufsize:v:0 19166176 -keyint_min:v:0 72 -r:v:0
23.976024627685547 -profile:v:0 main -c:a:0 copy -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts
disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB.m3u8" -segment_list_type m3u8
-segment_time 00:00:03.000 -segment_start_number 108 -individual_header_trailer 0 -write_header_trailer 0
-segment_write_temp 1 "C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_%d.ts"
-map 0:2 -map 0:0 -an -c:v:0 copy -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment
-map_metadata -1 -segment_format webvtt -segment_list
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s2.m3u8" -segment_list_type
m3u8 -segment_time 00:00:03.000 -segment_start_number 108 -break_non_keyframes 1 -individual_header_trailer 1
-write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:05:24.000
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s2_%d.vtt" -map 0:3 -map 0:0
-an -c:v:0 copy -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s3.m3u8" -segment_list_type
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s3_%d.vtt" -map 0:4 -map 0:0
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s4.m3u8" -segment_list_type
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s4_%d.vtt" -map 0:5 -map 0:0
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s5.m3u8" -segment_list_type
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s5_%d.vtt" -map 0:6 -map 0:0
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s6.m3u8" -segment_list_type
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s6_%d.vtt" -map 0:7 -map 0:0
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s7.m3u8" -segment_list_type
"C:\Users\Capt\AppData\Roaming\Emby-Server\programdata\transcoding-temp\27CEDB\27CEDB_s7_%d.vtt"}
The latest pre-release should resolve this issue. Please let me know if you see any improvement.
Doesn't seem to work.
Version 2025.01.27.2217
[/] Use HEVC for transcoding
Use HEVC (H.265) for transcoding instead of H.264 for streaming to client apps. Requires hardware that can handle encoding HEVC.
On the Amazon Fire 10 tablet it just shows a spinning circle as if waiting.
http://dvr-media-server.local:8089/admin/log
2025/01/29 14:51:51.421389 [HLS] ffmpeg: file568-ip10.0.0.34:  [hevc_nvenc @ 0x23958c0] InitializeEncoder failed: invalid param (8): Unsupported Level.
2025/01/29 14:51:51.447095 [HLS] ffmpeg: file568-ip10.0.0.34:  Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
2025/01/29 14:51:51.532525 [ENC] Encoder stopped after starting from 16 without encoding any segments. Marked segment as failed.
Does it work without HEVC enabled?
with HEVC disabled it displays the following error message on the Fire Tablet after 30 seconds:
! Connection Lost
The connection to Channels DVR Server had a problem. Press play to try again.
failed after 31.012173925s: hls: temporary failure while downloading: Get "http://10.0.0.250:8089/dvr/files/568/hls/stream.m3u8/stream0.ts?acodec=copy&bitrate=2000&indexed=true&level=40&resolution=576&scodec=copy&ssize=1&vcodec=h264": context canceled
Please submit diagnostics from the DVR.
This is what it shows in the log:
2025/01/29 16:20:51.976526 [ENC] Starting encoder in /home/capt/channels-data/Streaming/file568-ip10.0.0.34-721020452/encoder-0-1039637583 at 0 (0.000000) (encoder=h264_nvenc, codec=h264, acodec=copy, resolution=576, deinterlacer=blend, bitrate=2000, segment_size=0.01)
2025/01/29 16:20:52.134937 [HLS] ffmpeg: file568-ip10.0.0.34:  [tonemap @ 0x23dc8000] Tonemapping works on PQ only
2025/01/29 16:21:53.951757 [HLS] Stopping inactive session file568-ip10.0.0.34
You can submit diagnostics by doing to Support -> Troubleshooting -> Submit Diagnostic Logs from the web interface of the DVR and providing the ID it gives you.
Logs have been submitted as c01db35c-8ab5-41c6-b42b-2eab063c328e .
Could you try the latest pre-release and see if that resolves your issue?
If not, please run this to make a sample of the file you're having problems with:
 ffmpeg -ss 00:05:00 -i 'Shrek.2001.2160p.4K.BluRay.x265.10bit.AAC5.1-[YTS.MX].mkv' -t 5 -c copy output.mkv
and then upload it to our dropbox: https://www.dropbox.com/request/MMjICRc053JJpSBPDIfQ
After updating to the latest Channels DVR I am getting the following error in Chrome browser:
Your connection is not private
Attackers might be trying to steal your information from dvr-media-server.local (for example, passwords, messages, or credit cards). Learn more about this warning
net::ERR_CERT_AUTHORITY_INVALID
Turn on enhanced protection to get Chrome's highest level of security
Well, on the plus side it does seem to be working now.
On the down side, all 4 cores of my server CPU go to almost 100%.
Just want to add that when watching the same movie using Plex the CPU load stays fairly low.
I have a dumb question.
When I look at ffmpeg in the channels-dvr folder it shows the following:
ffmpeg version 5.0.2 Copyright (c) 2000-2022 the FFmpeg developers
Is this the version that Channels DVR is using?
Why isn't Channels using a newer version like 7.1?
I have no idea if this would make a difference with transcoding but it might.
