Trash Settings
I'm losing my mind, I can no longer find the setting to change when "Trash" automatically deletes a recording. I had it set to 2 days now it says 1 and no option to change it. Was it buried, moved, or eliminated?
Dvr ui. - settings. - Recordings & Passes. - Remove Items From Trash After
It’s right below padding and keep settings
Here's a screenshot to help you get your bearings:
Thanks I will take a look again. Thought it was on the client side but I did look at the server side yesterday,,, didn't see it.
