Troubleshooting TVE stream ending prematurely
also getting these errors:
2024/02/05 21:38:37.146456 [HLS] Couldn't generate stream playlist for ch6011-dTVE-Comcast_SSO-ip192.168.1.42: Playlist has not been updated in 25.0261414s
and
2024/02/05 21:44:38.774941 [HLS] ffmpeg: ch6011-dTVE-Comcast_SSO-ip192.168.1.42-remux: [hls @ 00000000027638c0] Timestamps are unset in a packet for stream 1. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
and
2024/02/05 22:00:09.676561 [HLS] Stopping inactive session ch6011-dTVE-Comcast_SSO-ip192.168.1.42
Just switched to direct stream mode and got this
2024/02/05 23:02:56.069658 [SNR] Rewriter statistics for 192.168.1.42 (office) for ch6011 CCP: discontinuity_detected=36 transport_errors=0 saw_pcr=true saw_pmt=true highest_pts=875.830167
discovery is good. thanks.
What are those other errors related to.
@techpro2004 I would have to see diagnostics from the DVR to have any idea.
submitted logs.
145ee881-f4b7-4678-8dca-4ab69dd1a08c
fyi, build 2024.02.06.0429 seems to be better. will test more over the next few days.
spoke too soon. new logs submitted.
fb94fc42-98a7-4171-a800-c718548770d9
It looks like you're running into network timeouts with the CDN:
2024/02/06 00:35:48.269573 [SNR] Streaming statistics for 192.168.1.42 (office) for ch6011 CCP: timeouts=8 segment_timeouts=8 playlist_timeouts=0
You may find out more information if you run the Resource Intensive Tests in Troubleshooting.
I switched to quad 9 dns and it seems good now. thanks.
however, I noticed the web ui seems slow to load. I have tried both firefox and edge. thanks.
