I have the HDHomeRun Connect on my network, and use wi-fi to send the signal to my AppleTV/Channels App.
Sometimes, I get very poor reception from the Channels app. I’ve used the HDHomerun signal meter, the signal strength is usually high 80s/low 90s, the strength and symbol quality are usually high 90s, but my network rate fluctuates.
Am I correct in assuming this is a wi-fi/network signal issue rather than an antenna issue?
