[ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:40.649337 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:40.712643 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:40.775780 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:40.917183 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:41.015346 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:41.075094 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:41.138995 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:41.203209 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:41.276431 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:41.335436 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:41.407209 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
2024/09/16 09:48:41.467991 [ERR] Error fetching tmdb episode: code: 34 | success: false | message: The resource you requested could not be found.
So when I go to the server address and try to fix a match for the Superman animated series(and it doesn't seem to be only that series I've tried other series and they haven't produced any errors but they haven't updated at all either with a new match), it says it's fixing the match and then the message goes away and I get these errors in my logs.
Thanks for any help.
