I was hoping to get some input on my problems with my Apple TVs the Apple TV in question is no more than 8 feet away from my router which is wired in to HDHR prime. Still I get connection lost or tuner not available on a regular basis lately I will include a copy of my log which I hope helps.
Thanks in advance for any help whatsoever
2018-07-08 16:11:35.449 read got (54) Connection reset by peer
2018-07-08 16:11:35.452 read got (0) Undefined error: 0
2018-07-08 16:11:35.454 read got (0) Undefined error: 0
2018-07-08 16:11:35.456 read got (0) Undefined error: 0
2018-07-08 16:11:35.458 read got (0) Undefined error: 0
2018-07-08 16:11:35.460 read got (0) Undefined error: 0
2018-07-08 16:11:35.462 read got (0) Undefined error: 0
2018-07-08 16:11:35.466 read got (0) Undefined error: 0
2018-07-08 16:11:35.469 read got (0) Undefined error: 0
2018-07-08 16:11:35.472 read got (0) Undefined error: 0
2018-07-08 16:11:35.475 read got (0) Undefined error: 0
2018-07-08 16:11:35.478 read got (0) Undefined error: 0
2018-07-08 16:11:35.481 read got (0) Undefined error: 0
2018-07-08 16:11:35.484 read got (0) Undefined error: 0
2018-07-08 16:11:35.487 read got (0) Undefined error: 0
2018-07-08 16:11:35.489 read got (0) Undefined error: 0
2018-07-08 16:11:35.491 read got (0) Undefined error: 0
2018-07-08 16:11:35.493 read got (0) Undefined error: 0
2018-07-08 16:11:35.495 read got (0) Undefined error: 0
2018-07-08 16:11:35.497 read got (0) Undefined error: 0
2018-07-08 16:11:35.499 streamer stopping after 231300 packets and 20 timeouts (11457 waits)
2018-07-08 16:11:35.527 [lavf] v: EOF reached.
2018-07-08 16:11:35.855 [ffmpeg/audio] error: ac3: incomplete frame
2018-07-08 16:11:35.871 [af] v: filter input EOF
2018-07-08 16:11:35.873 [af] v: filter output EOF
2018-07-08 16:11:35.876 [cplayer] v: audio EOF reached
2018-07-08 16:11:36.944 [ffmpeg/video] error: h264: error while decoding MB 42 20, bytestream -10
2018-07-08 16:11:36.947 [ffmpeg/video] v: h264: concealing 2007 DC, 2007 AC, 2007 MV errors in P frame
2018-07-08 16:11:37.041 [vf] v: filter input EOF
2018-07-08 16:11:37.045 [vf] v: filter output EOF
2018-07-08 16:11:37.057 event: audio-reconfig
2018-07-08 16:11:37.060 [cplayer] v: video EOF reached
2018-07-08 16:11:37.065 event: video-reconfig
2018-07-08 16:11:37.069 [cplayer] v: EOF code: 1
2018-07-08 16:11:37.074 [ad] v: Uninit decoder.
2018-07-08 16:11:37.078 [vd] v: Uninit decoder.
2018-07-08 16:11:37.086 event: tracks-changed
2018-07-08 16:11:37.125 event: end-file
2018-07-08 16:11:37.135 Updating playState from LTVideoPlayerPlayStatePlaying to LTVideoPlayerPlayStateError
2018-07-08 16:11:37.146 event: audio-reconfig
2018-07-08 16:11:37.149 event: video-reconfig
2018-07-08 16:11:37.152 [cplayer] v: finished playback, success (reason 0)
2018-07-08 16:11:37.155 [cplayer] info:
2018-07-08 16:11:37.158 [cplayer] v: Set property: aid=1 -> 1
2018-07-08 16:11:37.161 [cplayer] v: Set property: audio=1 -> 1
2018-07-08 16:11:37.164 [cplayer] v: Set property: sid=0 -> 1
2018-07-08 16:11:37.167 [cplayer] v: Set property: sub=0 -> 1
2018-07-08 16:11:47.043 Show Info Bar: (null)
2018-07-08 16:11:49.986 [cplayer] v: Set property: pause=false -> 1
2018-07-08 16:11:49.995 Updating playState from LTVideoPlayerPlayStateError to LTVideoPlayerPlayStateStopped
2018-07-08 16:11:50.003 Updating playState from LTVideoPlayerPlayStateStopped to LTVideoPlayerPlayStateLoading
2018-07-08 16:11:50.008 set streaming buffer to 128 segments (free bytes: 20962381824)
2018-07-08 16:11:50.012 Play Channel: {
Source = "Quick Guide";
2018-07-08 16:11:50.153 streamer unable to connect tcp socket: Connection refused
2018-07-08 16:11:50.157 streamer sent request to 192.168.0.100: tuner 2, channel <HRChannel:0x1c4367a40 number=828 name=CMDYD (CMDYD)> []
2018-07-08 16:11:50.765 event: start-file
2018-07-08 16:11:50.772 Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStateLoading
2018-07-08 16:11:50.781 [cplayer] info: Playing: cb://1531080710004
2018-07-08 16:11:50.786 [stream_callback] v: Opening cb://1531080710004
2018-07-08 16:11:50.790 [demux] v: Trying demuxers for level=force.
2018-07-08 16:11:51.428 streamer started receiving data
2018-07-08 16:11:51.472 [lavf] v: Found 'mpegts' at score=50 size=2048.
2018-07-08 16:11:51.475 [lavf] v: avformat_open_input() finished after 2048 bytes.
2018-07-08 16:11:51.479 event: tracks-changed
2018-07-08 16:11:51.496 event: tracks-changed
2018-07-08 16:11:51.505 event: tracks-changed
2018-07-08 16:11:51.509 event: metadata-update
2018-07-08 16:11:51.514 event: audio-reconfig
2018-07-08 16:11:51.519 event: audio-reconfig
2018-07-08 16:11:51.524 event: file-loaded
2018-07-08 16:11:51.529 [lavf] v: avformat_find_stream_info() skipped
2018-07-08 16:11:51.534 [demux] v: Detected file format: mpegts (libavformat)
2018-07-08 16:11:51.539 [cplayer] v: Opening done: cb://1531080710004
2018-07-08 16:11:51.544 [lavf] v: select track 0
2018-07-08 16:11:51.549 [lavf] v: select track 1
2018-07-08 16:11:51.553 [cplayer] info: (+) Video --vid=1 (h264)
2018-07-08 16:11:51.556 [cplayer] info: (+) Audio --aid=1 --alang=eng (ac3)
2018-07-08 16:11:51.559 [cplayer] info: Audio --aid=2 --alang=spa (ac3)
2018-07-08 16:11:51.563 [vd] v: Container reported FPS: 0.000000
2018-07-08 16:11:51.566 [vd] v: Codec list:
2018-07-08 16:11:51.569 [vd] v: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2018-07-08 16:11:51.572 [vd] v: Opening decoder h264
2018-07-08 16:11:51.576 [vd] v: Not trying to use hardware decoding: codec h264 is not on whitelist.
2018-07-08 16:11:51.580 [vd] v: Using software decoding.
2018-07-08 16:11:51.585 [vd] v: Detected 2 logical cores.
2018-07-08 16:11:51.590 [vd] v: Requesting 3 threads for decoding.
2018-07-08 16:11:51.594 [vd] v: Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10)
2018-07-08 16:11:51.598 [vf] v: User filter list:
2018-07-08 16:11:51.602 [vf] v: lavfi (lavfi.00)
2018-07-08 16:11:51.606 [ad] v: Codec list:
2018-07-08 16:11:51.611 [ad] v: ac3 - ATSC A/52A (AC-3)
2018-07-08 16:11:51.614 [ad] v: ac3_fixed (ac3) - ATSC A/52A (AC-3)
2018-07-08 16:11:51.617 [ad] v: ac3_at (ac3) - ac3 (AudioToolbox)
2018-07-08 16:11:51.620 [ad] v: Opening decoder ac3
2018-07-08 16:11:51.623 [ad] v: Requesting 1 threads for decoding.
2018-07-08 16:11:51.626 [ad] v: Selected codec: ac3 (ATSC A/52A (AC-3))
2018-07-08 16:11:51.629 [af] v: User filter list:
2018-07-08 16:11:51.633 [af] v: (empty)
2018-07-08 16:11:51.635 [cplayer] v: Starting playback...
2018-07-08 16:11:51.640 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.644 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.648 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.651 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.654 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.658 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.661 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.665 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.669 [af] v: [in] 48000Hz 5.1(side) 6ch floatp
2018-07-08 16:11:51.673 [af] v: format changed, draining filter chain
2018-07-08 16:11:51.675 [af] v: done format change draining
2018-07-08 16:11:51.677 [af] v: probing new format
2018-07-08 16:11:51.682 [af] v: [userspeed] 48000Hz 5.1(side) 6ch floatp
2018-07-08 16:11:51.685 event: audio-reconfig
2018-07-08 16:11:51.688 [af] v: [convert] 48000Hz 5.1(side) 6ch floatp
2018-07-08 16:11:51.689 [af] v: got output format from probing
2018-07-08 16:11:51.694 [ao] v: Trying audio driver 'audiounit'
2018-07-08 16:11:51.698 [ao/audiounit] v: requested format: 48000 Hz, 5.1(side) channels, floatp
2018-07-08 16:11:51.701 [ao/audiounit] v: using soft-buffer of 9600 samples.
2018-07-08 16:11:51.705 [cplayer] info: AO: [audiounit] 48000Hz stereo 2ch floatp
2018-07-08 16:11:51.708 [cplayer] v: AO: Description: AudioUnit (iOS)
2018-07-08 16:11:51.711 [autoconvert] v: inserting resampler
2018-07-08 16:11:51.714 [swresample] v: format change, reinitializing resampler
2018-07-08 16:11:51.717 [swresample] v: 48000Hz 5.1(side) floatp -> 48000Hz stereo floatp
2018-07-08 16:11:51.719 [swresample] v: Remix: 5.1(side) -> stereo
2018-07-08 16:11:51.721 [af] v: [convert] 48000Hz stereo 2ch floatp
2018-07-08 16:11:51.723 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.725 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.727 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.729 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.731 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.735 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.738 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.741 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.744 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.746 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.748 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.750 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.752 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.754 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.756 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.758 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.877 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.880 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.884 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.887 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.890 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.893 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.896 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.899 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.901 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.903 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.905 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.907 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.909 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:51.911 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.145 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.147 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.150 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.153 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.158 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.162 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.166 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.170 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.174 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.179 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.183 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.187 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.190 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.192 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.195 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.418 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.421 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.424 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.427 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.430 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.434 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.439 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.443 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.447 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.451 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.455 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.459 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.463 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.466 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.469 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.472 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.475 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.631 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.634 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.637 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.648 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:52.653 [vd] v: Decoder format: 1280x720 yuv420p auto/auto/auto/auto/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000)
2018-07-08 16:11:52.658 [vd] v: Forcing user-set aspect ratio.
2018-07-08 16:11:52.662 event: video-reconfig
2018-07-08 16:11:52.666 [vf] v: [in] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:52.670 event: video-reconfig
2018-07-08 16:11:52.675 [vf] v: [userdeint] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:52.679 [vf] v: [lavfi] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:52.683 [vf] v: [autorotate] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:52.686 [vf] v: [convert] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:52.689 [cplayer] info: VO: [libmpv] 1280x720 => 1280x720 yuv420p
2018-07-08 16:11:52.692 [cplayer] v: VO: Description: render API for libmpv
2018-07-08 16:11:52.695 [vo/libmpv] v: reconfig to 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:52.698 [cplayer] v: first video frame after restart shown
2018-07-08 16:11:53.778 [cplayer] v: starting audio playback
2018-07-08 16:11:53.964 event: playback-restart
2018-07-08 16:11:53.982 Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStatePlaying
2018-07-08 16:11:54.007 [cplayer] v: playback restart complete
2018-07-08 16:11:54.119 event: tracks-changed
2018-07-08 16:11:54.123 [cplayer] info: (+) Video --vid=1 (h264)
2018-07-08 16:11:54.129 [cplayer] info: (+) Audio --aid=1 --alang=eng (ac3)
2018-07-08 16:11:54.133 [cplayer] info: Audio --aid=2 --alang=spa (ac3)
2018-07-08 16:11:54.136 [cplayer] info: Subs --sid=1 (*) (eia_608)
2018-07-08 16:11:54.179 Show Info Bar: (null)
2018-07-08 16:11:55.755 read got (9) Bad file descriptor
2018-07-08 16:11:55.758 [cplayer] v: Set property: pause=false -> 1
2018-07-08 16:11:55.762 streamer stopping after 1600 packets and 1 timeouts (92 waits)
2018-07-08 16:11:55.769 Updating playState from LTVideoPlayerPlayStatePlaying to LTVideoPlayerPlayStateStopped
2018-07-08 16:11:55.787 [cplayer] v: EOF code: 4
2018-07-08 16:11:55.791 Updating playState from LTVideoPlayerPlayStateStopped to LTVideoPlayerPlayStateLoading
2018-07-08 16:11:55.820 set streaming buffer to 128 segments (free bytes: 20961943552)
2018-07-08 16:11:55.823 Play Channel: {
2018-07-08 16:11:55.829 event: audio-reconfig
2018-07-08 16:11:55.832 event: video-reconfig
2018-07-08 16:11:55.834 event: tracks-changed
2018-07-08 16:11:55.836 event: end-file
2018-07-08 16:11:55.838 event: audio-reconfig
2018-07-08 16:11:55.840 event: video-reconfig
2018-07-08 16:11:55.842 [ad] v: Uninit decoder.
2018-07-08 16:11:55.844 [vd] v: Uninit decoder.
2018-07-08 16:11:55.848 [cplayer] v: finished playback, success (reason 2)
2018-07-08 16:11:55.852 [cplayer] info:
2018-07-08 16:11:55.855 [cplayer] v: Set property: aid=1 -> 1
2018-07-08 16:11:55.858 [cplayer] v: Set property: audio=1 -> 1
2018-07-08 16:11:55.862 [cplayer] v: Set property: sid=0 -> 1
2018-07-08 16:11:55.865 [cplayer] v: Set property: sub=0 -> 1
2018-07-08 16:11:55.961 streamer unable to connect tcp socket: Connection refused
2018-07-08 16:11:55.963 streamer sent request to 192.168.0.100: tuner 2, channel <HRChannel:0x1c4367b00 number=829 name=SYFYD (SYFYD)> []
2018-07-08 16:11:56.531 event: start-file
2018-07-08 16:11:56.536 Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStateLoading
2018-07-08 16:11:56.538 [cplayer] info: Playing: cb://1531080715818
2018-07-08 16:11:56.540 [stream_callback] v: Opening cb://1531080715818
2018-07-08 16:11:56.543 [demux] v: Trying demuxers for level=force.
2018-07-08 16:11:57.233 streamer started receiving data
2018-07-08 16:11:57.247 [lavf] v: Found 'mpegts' at score=50 size=2048.
2018-07-08 16:11:57.251 [lavf] v: avformat_open_input() finished after 2048 bytes.
2018-07-08 16:11:57.255 event: tracks-changed
2018-07-08 16:11:57.271 event: tracks-changed
2018-07-08 16:11:57.274 event: tracks-changed
2018-07-08 16:11:57.277 event: metadata-update
2018-07-08 16:11:57.279 event: audio-reconfig
2018-07-08 16:11:57.280 event: audio-reconfig
2018-07-08 16:11:57.283 event: file-loaded
2018-07-08 16:11:57.285 [lavf] v: avformat_find_stream_info() skipped
2018-07-08 16:11:57.287 [demux] v: Detected file format: mpegts (libavformat)
2018-07-08 16:11:57.289 [cplayer] v: Opening done: cb://1531080715818
2018-07-08 16:11:57.292 [lavf] v: select track 0
2018-07-08 16:11:57.297 [lavf] v: select track 1
2018-07-08 16:11:57.300 [cplayer] info: (+) Video --vid=1 (h264)
2018-07-08 16:11:57.303 [cplayer] info: (+) Audio --aid=1 --alang=eng (ac3)
2018-07-08 16:11:57.306 [cplayer] info: Audio --aid=2 --alang=spa (ac3)
2018-07-08 16:11:57.311 [vd] v: Container reported FPS: 0.000000
2018-07-08 16:11:57.321 [vd] v: Codec list:
2018-07-08 16:11:57.324 [vd] v: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2018-07-08 16:11:57.333 [vd] v: Opening decoder h264
2018-07-08 16:11:57.336 [vd] v: Not trying to use hardware decoding: codec h264 is not on whitelist.
2018-07-08 16:11:57.338 [vd] v: Using software decoding.
2018-07-08 16:11:57.341 [vd] v: Detected 2 logical cores.
2018-07-08 16:11:57.343 [vd] v: Requesting 3 threads for decoding.
2018-07-08 16:11:57.345 [vd] v: Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10)
2018-07-08 16:11:57.347 [vf] v: User filter list:
2018-07-08 16:11:57.349 [vf] v: lavfi (lavfi.00)
2018-07-08 16:11:57.352 [ad] v: Codec list:
2018-07-08 16:11:57.355 [ad] v: ac3 - ATSC A/52A (AC-3)
2018-07-08 16:11:57.359 [ad] v: ac3_fixed (ac3) - ATSC A/52A (AC-3)
2018-07-08 16:11:57.365 event: audio-reconfig
2018-07-08 16:11:57.371 [ad] v: ac3_at (ac3) - ac3 (AudioToolbox)
2018-07-08 16:11:57.373 [ad] v: Opening decoder ac3
2018-07-08 16:11:57.377 [ad] v: Requesting 1 threads for decoding.
2018-07-08 16:11:57.380 [ad] v: Selected codec: ac3 (ATSC A/52A (AC-3))
2018-07-08 16:11:57.385 [af] v: User filter list:
2018-07-08 16:11:57.390 [af] v: (empty)
2018-07-08 16:11:57.395 [cplayer] v: Starting playback...
2018-07-08 16:11:57.400 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.404 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.409 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.413 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.417 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.420 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.423 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.426 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.429 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.432 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.435 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.438 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.441 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.445 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.449 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.453 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.457 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.461 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.465 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.470 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.474 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.476 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.479 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.483 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.486 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.489 [af] v: [in] 48000Hz 5.1(side) 6ch floatp
2018-07-08 16:11:57.493 [af] v: format changed, draining filter chain
2018-07-08 16:11:57.514 [af] v: done format change draining
2018-07-08 16:11:57.515 [af] v: probing new format
2018-07-08 16:11:57.522 [af] v: [userspeed] 48000Hz 5.1(side) 6ch floatp
2018-07-08 16:11:57.526 [af] v: [convert] 48000Hz 5.1(side) 6ch floatp
2018-07-08 16:11:57.531 [af] v: got output format from probing
2018-07-08 16:11:57.536 [ao] v: Trying audio driver 'audiounit'
2018-07-08 16:11:57.540 [ao/audiounit] v: requested format: 48000 Hz, 5.1(side) channels, floatp
2018-07-08 16:11:57.544 [ao/audiounit] v: using soft-buffer of 9600 samples.
2018-07-08 16:11:57.549 [cplayer] info: AO: [audiounit] 48000Hz stereo 2ch floatp
2018-07-08 16:11:57.553 [cplayer] v: AO: Description: AudioUnit (iOS)
2018-07-08 16:11:57.557 [autoconvert] v: inserting resampler
2018-07-08 16:11:57.560 [swresample] v: format change, reinitializing resampler
2018-07-08 16:11:57.563 [swresample] v: 48000Hz 5.1(side) floatp -> 48000Hz stereo floatp
2018-07-08 16:11:57.566 [swresample] v: Remix: 5.1(side) -> stereo
2018-07-08 16:11:57.569 [af] v: [convert] 48000Hz stereo 2ch floatp
2018-07-08 16:11:57.572 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.575 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.578 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.581 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.586 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.591 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.596 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.600 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.604 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.608 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.612 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.616 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.619 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.622 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.624 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.626 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.766 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.768 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.771 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.778 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.783 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.784 event: video-reconfig
2018-07-08 16:11:57.788 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.791 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.794 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.797 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.799 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.801 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.803 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.805 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.807 [vd] warn: Error while decoding frame (-1094995529)!
2018-07-08 16:11:57.809 [vd] v: Decoder format: 1280x720 yuv420p auto/auto/auto/auto/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000)
2018-07-08 16:11:57.811 [vd] v: Forcing user-set aspect ratio.
2018-07-08 16:11:57.813 [vf] v: [in] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:57.817 [vf] v: [userdeint] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:58.042 [vf] v: [lavfi] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:58.045 event: video-reconfig
2018-07-08 16:11:58.051 [vf] v: [autorotate] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:58.054 [vf] v: [convert] 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:58.058 event: video-reconfig
2018-07-08 16:11:58.061 [cplayer] info: VO: [libmpv] 1280x720 => 1280x720 yuv420p
2018-07-08 16:11:58.062 [cplayer] v: VO: Description: render API for libmpv
2018-07-08 16:11:58.065 [vo/libmpv] v: reconfig to 1280x720 [134217729:134217728] yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2018-07-08 16:11:58.066 [cplayer] v: first video frame after restart shown
2018-07-08 16:11:59.141 [cplayer] v: starting audio playback
2018-07-08 16:11:59.340 event: playback-restart
2018-07-08 16:11:59.359 Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStatePlaying
2018-07-08 16:11:59.374 [cplayer] v: playback restart complete
2018-07-08 16:11:59.531 event: tracks-changed
2018-07-08 16:11:59.537 [cplayer] info: (+) Video --vid=1 (h264)
2018-07-08 16:11:59.545 [cplayer] info: (+) Audio --aid=1 --alang=eng (ac3)
2018-07-08 16:11:59.551 [cplayer] info: Audio --aid=2 --alang=spa (ac3)
2018-07-08 16:11:59.553 [cplayer] info: Subs --sid=1 (*) (eia_608)
2018-07-08 16:13:42.450 [af] v: [in] 48000Hz stereo 2ch floatp
2018-07-08 16:13:42.453 [af] v: format changed, draining filter chain
2018-07-08 16:13:42.457 [af] v: done format change draining
2018-07-08 16:13:42.461 [af] v: probing new format
2018-07-08 16:13:42.462 [af] v: [userspeed] 48000Hz stereo 2ch floatp
2018-07-08 16:13:42.464 [swresample] v: format change, reinitializing resampler
2018-07-08 16:13:42.466 [swresample] v: 48000Hz stereo floatp -> 48000Hz stereo floatp
2018-07-08 16:13:42.468 [af] v: got output format from probing
2018-07-08 16:13:42.668 event: audio-reconfig
2018-07-08 16:13:42.672 [ao] v: Trying audio driver 'audiounit'
2018-07-08 16:13:42.675 [ao/audiounit] v: requested format: 48000 Hz, stereo channels, floatp
2018-07-08 16:13:42.698 [ao/audiounit] v: using soft-buffer of 9600 samples.
2018-07-08 16:13:42.701 [cplayer] info: AO: [audiounit] 48000Hz stereo 2ch floatp
2018-07-08 16:13:42.705 event: audio-reconfig
2018-07-08 16:13:42.708 [cplayer] v: AO: Description: AudioUnit (iOS)
2018-07-08 16:15:12.641 [af] v: [in] 48000Hz 5.1(side) 6ch floatp
2018-07-08 16:15:12.646 [af] v: format changed, draining filter chain
2018-07-08 16:15:12.650 [af] v: done format change draining
2018-07-08 16:15:12.654 [af] v: probing new format
2018-07-08 16:15:12.658 [af] v: [userspeed] 48000Hz 5.1(side) 6ch floatp
2018-07-08 16:15:12.662 [af] v: [convert] 48000Hz 5.1(side) 6ch floatp
2018-07-08 16:15:12.666 [af] v: got output format from probing
2018-07-08 16:15:12.862 event: audio-reconfig
2018-07-08 16:15:12.866 [ao] v: Trying audio driver 'audiounit'
2018-07-08 16:15:12.871 [ao/audiounit] v: requested format: 48000 Hz, 5.1(side) channels, floatp
2018-07-08 16:15:12.898 [ao/audiounit] v: using soft-buffer of 9600 samples.
2018-07-08 16:15:12.900 [cplayer] info: AO: [audiounit] 48000Hz stereo 2ch floatp
2018-07-08 16:15:12.903 event: audio-reconfig
2018-07-08 16:15:12.906 [cplayer] v: AO: Description: AudioUnit (iOS)
2018-07-08 16:15:12.910 [autoconvert] v: inserting resampler
2018-07-08 16:15:12.914 [swresample] v: format change, reinitializing resampler
2018-07-08 16:15:12.918 [swresample] v: 48000Hz 5.1(side) floatp -> 48000Hz stereo floatp
2018-07-08 16:15:12.924 [swresample] v: Remix: 5.1(side) -> stereo
2018-07-08 16:15:12.929 [af] v: [convert] 48000Hz stereo 2ch floatp
2018-07-08 16:28:16.298 jsonpipe failed with Error Domain=NSURLErrorDomain Code=-1005 "The network connection was lost." UserInfo={NSUnderlyingError=0x1c604e190 {Error Domain=kCFErrorDomainCFNetwork Code=-1005 "(null)" UserInfo={NSErrorPeerAddressKey=<CFData 0x1c0280550 [0x1a9f5fcb8]>{length = 16, capacity = 16, bytes = 0x10021f99c0a800670000000000000000}, _kCFStreamErrorCodeKey=54, _kCFStreamErrorDomainKey=1}}, NSErrorFailingURLStringKey=http://192.168.0.103:8089/dvr/events/subscribe, NSErrorFailingURLKey=http://192.168.0.103:8089/dvr/events/subscribe, _kCFStreamErrorDomainKey=1, _kCFStreamErrorCodeKey=54, NSLocalizedDescription=The network connection was lost.}
2018-07-08 16:28:16.300 jsonpipe will reconnect in 1.000000s
2018-07-08 16:28:17.515 jsonpipe failed with Error Domain=NSURLErrorDomain Code=-1004 "Could not connect to the server." UserInfo={NSUnderlyingError=0x1c4c583c0 {Error Domain=kCFErrorDomainCFNetwork Code=-1004 "(null)" UserInfo={_kCFStreamErrorCodeKey=61, _kCFStreamErrorDomainKey=1}}, NSErrorFailingURLStringKey=http://192.168.0.103:8089/dvr/events/subscribe, NSErrorFailingURLKey=http://192.168.0.103:8089/dvr/events/subscribe, _kCFStreamErrorDomainKey=1, _kCFStreamErrorCodeKey=61, NSLocalizedDescription=Could not connect to the server.}
2018-07-08 16:28:17.519 jsonpipe will reconnect in 2.000000s
2018-07-08 16:28:19.994 jsonpipe failed with Error Domain=NSURLErrorDomain Code=-1004 "Could not connect to the server." UserInfo={NSUnderlyingError=0x1c4c5d310 {Error Domain=kCFErrorDomainCFNetwork Code=-1004 "(null)" UserInfo={_kCFStreamErrorCodeKey=61, _kCFStreamErrorDomainKey=1}}, NSErrorFailingURLStringKey=http://192.168.0.103:8089/dvr/events/subscribe, NSErrorFailingURLKey=http://192.168.0.103:8089/dvr/events/subscribe, _kCFStreamErrorDomainKey=1, _kCFStreamErrorCodeKey=61, NSLocalizedDescription=Could not connect to the server.}
2018-07-08 16:28:19.999 jsonpipe will reconnect in 4.000000s
