Hi today I’ve suddenly got tuner not available coming up for my prime tuner the other tuners work ok and it sees the prime tuner. The prime tuner works with Vic and HDHomeRun but not channels I’ve restarted and deleted to no avail
Does the settings tab show the correct IP for your prime?
Also check the dvr web UI, and use Scan Network if the IP is wrong there.
Ok will check that did a network scan for tuners your possibly right as my router is being crappy at the moment I’ll check when I get home thanks
