Tuner Priority Not ding Followed
I have three sources on my Channels DVR. The original source was TVE and then I added Locast and then some custom channels to access my security cams. I have passes setup that could record on either Locast or TVE. My highest priority tuner is Locast and second is TVE. I have multiple passes that will record from TVE instead of Locast. This would not normally be a big deal. It the local affiliate for Fox is blacking out shows on TVE so I get long screen during recording to tell me the show is not available.
I have tried changing the priority and changing it back in the web settings and I can force the channel number but if set to Any Channel it will not follow the priority. Is there something that overrides the tuner priority list that I am missing?
Thank you for any suggestions!
This is how it's supposed to work > https://getchannels.com/docs/getting-started/faqs/channels-plus/#how-does-the-dvr-pick-which-tuner-to-use-to-make-a-recording
