I had a few recordings fail this week, apparently because of an odd combination of tuner fallback glitches. I have my sources ordered with my Prime cable tuner on top, then my Quatro OTA tuner, then my HDHR5-4K (Flex) OTA tuner. A few days ago some show passes that were defaulting to cable were assigned to an OTA channel. Maybe my cable went out long enough for Channels DVR to automatically change that?
OK. But then those passes remained assigned to that OTA channel and only that OTA channel for at least five days, even though at least one more OTA channel was available for the same TV network, and even though my cable was working fine the rest of the week.
Worse, it was a "phantom channel" from another market. Hooray for the improved sensitivity of the HDHR5-4K. But oh-oh: when Channels DVR tried to record that receive path was gone, Channels DVR reported no signal, and the recordings failed.
That phantom channel was on the HDHR5-4K tuner, the lowest-priority tuner in the list. For example, when the priority channel should have been cable 1005 or 705, and the fallback should have been to OTA channel 5.1 on the Quatro, it Instead went to the HDHR-4K tuner and the phantom channel 13.1. So the fallback logic apparently selects a higher channel number even if it's on a lower-priority tuner? And apparently seeks no further if that channel fails?
OK so the phantom channel thing is not likely to happen to everyone, and in fact another show on a different channel was affected as well but it fell back to a working channel: 1009 cable to 9.1 OTA. But why did Channels DVR fall back two tuners down the list, and stay there for five days just for those four shows? If there was a cable glitch it did not persist, because other shows on cable recorded just fine all week. The DVR schedule showed no other channel on the future schedule for each of the failed shows, just that lowest-priority OTA channel alone, until I noticed while clicking around the web UI. And yes, I've hidden that phantom channel now, lol, as well as manually assigning the cable channel in those passes just to be extra safe, but I wonder if there's something else I can do or if the logic behind this can be fixed.
