Satisfied Channels DVR for several years. one item of concern is the reliance on HD Homerun tuners as the only supported tuners. is there any possibility to include other brands of tv tuners , like plex does ?
A quick search brought up this recent post:
My reading of that is that there are no intentions to support other hardware tuners directly.
I think you are right , I dont believe adding tuner support is in the works for Channels
- apparently tablo tuners may be usable via custom channels per the thread you forwarded
well, I guess the superb performance of the Channels DVR is due in large part to the tight integration of software and hardware - so we will live with it. hopefully Silicon dust will be in business for a long time.
