Prerelease fixed my issues.
not for me. still playback failed on tnt and tbs both.
still broken for xfinity, at least tbs and tnt are.
after a full reboot on update, it's fixed. i think the problem is that my disk was almost full...after clearing some space, seems to be working. not sure if it was that or the reboot that resolved it.
Tcm = tuner not available
Tcm app works fine
login ATT creds
Using latest pre release version..
Rescanned channels
TNT works
Tbs works
Any suggestions (tcm worked prior to this with these creds...)
Thx
I had to update to the latest prerelease and rescan TCM (only) yesterday but things are now working. However we’re on Verizon Fios, not AT&T.
Wow thanks for quick response ,
Believe I am running latest pre-release
2020.12.29.0234 I hit check update and I am up to date....(message back)
I have rescanned all channels (211)..
And restarted the app too (Apple TV)
Can I roll back then roll forward again on version?
The current pre-release is 2021.01.09.2109.
Also, using this version with DirecTV credentials, no problems with any WarnerMedia streams. TNT, TBS, TCM, et al.
Further up. Click and hold the "check for update" under " Status About this server"
Thanks found it and looks like that may have fixed it!
Fixed it for me as well.
