So, I wanted to see if I can get FXX added to Channels TV, since I can get it using the Spectrum TV app, but when I enabled TV Anywhere in the Settings\Advanced, it only found one channel, as far as I can tell, and that wasn't FXX. Am I doing something wrong? Is there a guide somewhere on how to add these channels to my lineup? The instructions I followed were found in a google search.
Did you add spectrum as a TVE provider under web ui> settings>sources>add source>chooseTVE provider and setup?
FXX is Disney owned and Disney recently DRM’d their feeds. So you can’t get any Disney family channels through TVE anymore. Search for PrismCast as an alternative to getting them into channels dvr.
Thanks. I did a quick search, and that looks like pretty complicated. I'm running Channels on a Synology, so it was pretty straightforward to just download the package. BTW, I am using TV Everywhere as my source for Spectrum channels, and have 110 channels currently - most of which I don't watch.
Ya a NAS isn’t going to handle PrismCast.
@Rice is correct. I have both Spectrum and Directv as TVE sources and none of the FX channels show up.
Out of all the options currently available, it's surprisingly simple, and the developer was gracious enough to support most operating system options, even for us die-hard native Windows users. As mentioned, it does require some server hardware horsepower that a NAS probably won't have.
