We’ve been using the Channels app with a HDHomeRun (HDHR) for over a year, and we love it. Flawless. That is up until the other day. I’ve noticed on our 2x ATV4, TV has been choppy and takes longer to start the TV channels. As if the reception was poor.
The HDHR reception is high 70’s % and the Signal and Symbol are 100%.
HDHR is ethernet cabled to our Orbi mesh network.
Through my testing of watching the same channel on our ATV4’s vs the HDHR macOS app, the issue is only present on the ATV4’s (Channels app). Works fine on the macOS app.
Checking the HDHR stats when testing, I can clearly see what is happening. The data rate between the HDHR is flapping when using the Channel app on our two ATV4’s, but is fine on the macOS app. That is the Mbps is around 0-1 when it’s using Channels app, when using the macOS app it’s 6-11Mbps.
This is some what of an isolation to the issue being the channel app. I can see in the version history the 3.1.11 was only released the other day, which matches up to when the issue started.
Hoping to have this fixed please in the next update? Please let me know if I can provide you with anything to help - this is the first time on here to submit a problem (as I said, been using it for over a year without a problem until now!).
Thanks
