TV everywhere all Discovery, food networks not working
I have Fubo and DIRECTV. Tv everywhere from the entire discovery network, food, cooking ect… will not come in. Tried to rescan and update everything but they are not even listing as scanned. Anybody having issues?
The discovery channels aren't part of fubo on Tv Everywhere.
The philo log in that has the same channels that are missing are working here. I can only assume it has to do with the log in of directv
You may need to update your server to the current Prerelease version. It fixes DirecTV TVE access.
I have a Philo login as well, and none of the discovery channels are working. I tried using the Discovery channels on 11-14 (Friday) and got a no login field error. I rescanned did the Prerelease upgrade just now, and the Discovery channels are still not working.
The following channels show the error:Discovery,Food,Animal-Planet,HGTV,TLC,Travel,Investigation-Discovery,DIY,Cooking-Channel,Science,AHC,Destination-America,Discovery-Life,Motortrend
"adobe auth reg code: no login form found"
Some of these failed during my overnight test scan (around 6:30am ET), but a manual test this morning and they seem fine. Cox, FWIW.
I'm seeing some chatter of Cloudflare issues again today, so there might be some temporary disruptions that should hopefully clear up through the day. AAMOF, as I was typing this, the Channels Community Board went down with a Cloudflare error!!
Win 11, Directv Stream
Latest Stable release.
Also failing on those channels.
I just checked my system (Fubo,Philo). Food, AHC, Travel, all working. Discovery was working, but a bit flaky.
The developers recently delivered a fix for DirecTV in a pre-release.
When it comes to TVE, fixes are made very frequently in pre-releases.
Still isn't working. Rebooted Windows 10 Server, upgraded to the pre-release again this evening, all those channels are still failing with the same error for Philo (adobe auth reg code: no login form found)
FIX
What worked for me was deleting Philo from channels completely from the sources. Add Philo again, login again to your Philo account (usually a email link) and let channels do the scan. Upon completing the scan all the Discovery channels were available again. Hope this helps others.
