I just set up the Channels server on a raspberry pi 4, 4 GB RAM. The antenna channels from my flex 4K load instantly. However, when I try to watch a TV everywhere channels like ESPN, HGTV the channels take up to a minute to load on Apple devices. I have a Apple TV 4K first generation and an Apple TV 4K second generation and iPhone XR. Otherwise, everything works flawlessly. Once I actually get a channel tuned in there’s no issues whatsoever. I just wish I could get it to load the Channels faster. Any recommendations? I did submit diagnostics DVR Diagnostic Log c1be6eaf-7cd5-4efd-b469-69477dee7b8b.
Not that I can help you much. But once you connect to the espn or hgtv. Go to another channel and then back. Does it connect you faster? Otherwise it might be a slow login due to re credentialing. I do run into slow logins with my nas but generally takes less than 10 seconds to maybe 15 at the worst.
Sounds like there is some issue for the initial connection. Does the same happen if you try to stream from the networks' sites from a web browser on the system hosting the DVR server?
Re-authentication can take a while at times, but it should only be an issue about once a month. Another possibility could be the hard drive for your DVR recordings is sleeping, and the extra time is needed to wake the drive and get the platters spinning.
Unfortunately, it’s still slow and changing channels.
Watching in a web browser is much faster. It takes a few seconds but it’s a noticeable difference. So the issue seems to be when trying to watch TV everywhere channels from the Channels app on my devices but not from the web.
Do this speed test on the browser where the IP address is the address of your client, to confirm that the dvr/client connections is good
This doesn't necessarily dismiss the sleeping hard drive. If you access the web UI, the drive needs to spin up to access the data, so once it is up, of course it is going to be more responsive. I suppose it depends upon:
- the type of hard drive your DVR is using as its primary storage
- the OS running your DVR
- the firmware/power mode/SMART settings of the drive itself
But his earlier test of switching between channels ie once a TVE channel is already running, should exclude it to be the drive specifically.
I put in my IP address but it won’t let me test the speed.
I would check the DVR log when you experience that with a client.
Since the client has to ask the DVR to tune the channel you should see what's happening in the log.
You also state that tuning your flex 4k is instant. Do you have tuner sharing enabled on the clients?
If not they go directly to the tuner and bypass Channels DVR when viewing OTA from the flex.
No, it shouldn't. There are so many wild and disparate variables, that there is no way without being there ourselves to know. People giving information in a tech support situation often don't know exactly what is influencing what, so they don't share everything.
That is why details, and specific information, and the exact steps used to recreate the problem are necessary. Anything else is simply guesswork.
For all we know there is a crappy LED light within range of his Apple TV that is interfering with initial stream. But, we're not there, so we only guess.
That should work for the Apple TV
https://getchannels.com/docs/getting-started/faqs/channels-apps/#how-can-i-test-the-network-speed-at-my-tv
Maybe you missed "Then launch Channels and make sure it is visible on the screen"
Here’s some of my logs from today. It looks like it could be a TV authentication issue with YouTube TV. I’m gonna try changing to another source rather than YouTube TV and see if that helps. I have access to DIRECTV and Verizon.
2021/12/31 15:22:14.917231 [DVR] pruned 341 replaced airings in 0s.
2021/12/31 15:22:24.537499 [DVR] Reindexed 2889 airings into XMLTV-Pluto (342 channels over 23h0m0s) + 3238 skipped [9s index]
2021/12/31 15:22:24.643788 [DVR] pruned 1230 replaced airings in 0s.
2021/12/31 15:22:24.649215 [IDX] Pruned 78 expired groups from XMLTV-STIRR in 5.120166ms.
2021/12/31 18:22:30.026032 [DVR] Reindexed 1627 airings into XMLTV-Pluto (342 channels over 16h45m0s) + 4500 skipped [5s index]
2021/12/31 18:22:30.119564 [DVR] pruned 1230 replaced airings in 0s.
2021/12/31 18:22:30.461350 [DVR] Fetched guide data for XMLTV-STIRR in 0s
2021/12/31 18:22:36.888749 [DVR] Indexed 2670 airings into XMLTV-STIRR (104 channels over 39h0m0s) + 87 skipped [6s index]
2021/12/31 18:22:36.916353 [DVR] pruned 338 replaced airings in 0s.
2021/12/31 18:22:36.938879 [IDX] Pruned 77 expired groups from XMLTV-STIRR in 22.217662ms.
2021/12/31 19:06:08.212270 [ERR] Failed to request m3u for MLB: Get "http://mlblive-akc.mlb.com/ls01/mlbam/mlb_network/NETWORK_LINEAR_1/master_wired.m3u8": dial tcp: lookup mlblive-akc.mlb.com on 127.0.0.53:53: no such host
2021/12/31 19:07:00.893516 [ERR] Failed to parse m3u for FoxWeather: unexpected URL without #EXTINF header
2021/12/31 19:11:39.890107 [IDX] Pruned 0 expired groups from X-M3U in 201.647µs.
2021/12/31 19:12:24.592987 [TNR] Opened connection to M3U-FoxWeather for ch9450 FOX WEATHER
2021/12/31 19:12:29.197303 [TNR] Closed connection to M3U-FoxWeather for ch9450 FOX WEATHER
2021/12/31 19:17:13.373010 [TNR] Closed connection to TVE-Verizon for ch6140 ESPN1
2021/12/31 19:17:20.672124 [TVE] stream timestamps: espn1: start_at=2021-12-31T19:16:40-06:00 current_at=2021-12-31T19:16:54-06:00 end_at=2021-12-31T19:16:59-06:00
2021/12/31 19:17:20.672392 [TNR] Opened connection to TVE-Verizon for ch6140 ESPN1
2021/12/31 20:04:56.911751 [TNR] Closed connection to TVE-Verizon for ch6140 ESPN1
2021/12/31 20:05:35.519666 [TNR] Opened connection to M3U-FoxWeather for ch9450 FOX WEATHER
2021/12/31 20:05:48.124048 action=authz_retry err=notAuthorized: User must re-authenticate
2021/12/31 20:05:48.124330 [TVE] action=auth mvpd=YouTubeTV requestor=nbcentertainment
2021/12/31 20:05:48.814087 [TVE] action=error_response type=Other error=net::ERR_UNKNOWN_URL_SCHEME url=
2021/12/31 20:05:48.820262 [TVE] action=version product=HeadlessChrome/89.0.4389.114 jsVersion=8.9.255.24 protocol=1.3 revision=@1ea76e193b4fadb723bfea2a19a66c93a1bc0ca6
2021/12/31 20:05:48.822781 [TVE] action=mock
2021/12/31 20:05:48.849614 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=YouTubeTV&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2021/12/31 20:05:48.852502 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2021/12/31 20:05:49.069881 [TVE] action=wait_for_page
2021/12/31 20:05:49.244089 [TVE] action=request type=Document method=POST url=https://youtube.auth-gateway.net/saml/saml2/idp/SSOService.php
2021/12/31 20:05:49.244187 [TVE] action=auth_domain domain=youtube.auth-gateway.net
2021/12/31 20:05:49.816596 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:05:49.897285 [TNR] Closed connection to M3U-FoxWeather for ch9450 FOX WEATHER
2021/12/31 20:05:50.019009 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:05:50.089713 [TVE] action=request type=Document method=GET url=https://accounts.google.com/o/oauth2/auth
2021/12/31 20:05:57.754600 [TVE] action=page_ready
2021/12/31 20:05:57.754711 [TVE] action=wait_for_page done=true reason=page_ready
2021/12/31 20:05:57.754761 [TVE] action=fill_form u=
2021/12/31 20:05:57.770410 [TVE] action=tvejs msg="googleLogin"
2021/12/31 20:05:57.851030 [TVE] action=wait_for_auth
2021/12/31 20:06:00.347190 [TVE] action=tvejs msg="googleLoginPassword"
2021/12/31 20:06:17.965851 action=authz_retry err=notAuthorized: User must re-authenticate
2021/12/31 20:06:17.966039 [TVE] action=auth mvpd=YouTubeTV requestor=nbcentertainment
2021/12/31 20:06:18.643236 [TVE] action=error_response type=Other error=net::ERR_UNKNOWN_URL_SCHEME url=
2021/12/31 20:06:18.649142 [TVE] action=version product=HeadlessChrome/89.0.4389.114 jsVersion=8.9.255.24 protocol=1.3 revision=@1ea76e193b4fadb723bfea2a19a66c93a1bc0ca6
2021/12/31 20:06:18.651725 [TVE] action=mock
2021/12/31 20:06:18.678965 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=YouTubeTV&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2021/12/31 20:06:18.682848 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2021/12/31 20:06:18.967086 [TVE] action=wait_for_page
2021/12/31 20:06:19.142119 [TVE] action=request type=Document method=POST url=https://youtube.auth-gateway.net/saml/saml2/idp/SSOService.php
2021/12/31 20:06:19.142206 [TVE] action=auth_domain domain=youtube.auth-gateway.net
2021/12/31 20:06:19.460851 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:06:19.667310 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:06:19.743405 [TVE] action=request type=Document method=GET url=https://accounts.google.com/o/oauth2/auth
2021/12/31 20:06:21.851557 [TVE] action=auth_timed_out
2021/12/31 20:06:21.851646 [TVE] action=screenshot
2021/12/31 20:06:22.026833 [TVE] action=screenshot size=34131
2021/12/31 20:06:22.033879 [TVE] action=capture_html
2021/12/31 20:06:22.545010 [TVE] action=capture_html size=1851450
2021/12/31 20:06:22.661273 [ERR] Could not start stream for TVE-YouTubeTV ch6073 FNC: TVE: Cable provider authentication failed
2021/12/31 20:06:27.671079 [TVE] action=page_ready
2021/12/31 20:06:27.671203 [TVE] action=wait_for_page done=true reason=page_ready
2021/12/31 20:06:27.671253 [TVE] action=fill_form u=
2021/12/31 20:06:27.682781 [TVE] action=tvejs msg="googleLogin"
2021/12/31 20:06:27.782365 [TVE] action=wait_for_auth
2021/12/31 20:06:30.277230 [TVE] action=tvejs msg="googleLoginPassword"
2021/12/31 20:06:48.870388 [TVE] stream timestamps: espn1: start_at=2021-12-31T20:06:08-06:00 current_at=2021-12-31T20:06:23-06:00 end_at=2021-12-31T20:06:27-06:00
2021/12/31 20:06:48.871373 [TNR] Opened connection to TVE-Verizon for ch6140 ESPN1
2021/12/31 20:06:51.782750 [TVE] action=auth_timed_out
2021/12/31 20:06:51.782918 [TVE] action=screenshot
2021/12/31 20:06:51.954250 [TVE] action=screenshot size=34131
2021/12/31 20:06:51.954952 [TVE] action=capture_html
2021/12/31 20:06:52.451436 [TVE] action=capture_html size=1848992
2021/12/31 20:06:52.570617 [ERR] Could not start stream for TVE-YouTubeTV ch6140 ESPN1: TVE: Cable provider authentication failed
2021/12/31 20:07:28.865413 [TNR] Sharing existing connection to TVE-Verizon for ch6140 ESPN1 (clients=2, len=0)
2021/12/31 20:07:28.868561 [HLS] Starting transcoder for channel 6140 from 192.168.1.200 (encoder=remux, resolution=, deinterlacer=, bitrate=7887)
2021/12/31 20:07:31.225157 [HLS] Probed live stream in 2.356253162s: h264 1280x720 progressive 4939192bps
2021/12/31 20:07:32.688407 [HLS] Session ch6140-dANY-ip192.168.1.200 started in 3.826078655s
2021/12/31 20:07:41.631937 [HLS] Stopping transcoder session ch6140-dANY-ip192.168.1.200 (out: 10.225044s, finished: false)
2021/12/31 20:07:47.647190 [TVE] stream timestamps: hgtv: start_at=2021-12-31T20:06:47-06:00 current_at=2021-12-31T20:07:08-06:00 end_at=2021-12-31T20:07:16-06:00
2021/12/31 20:07:47.647730 [TNR] Opened connection to TVE-DTV for ch6104 HGTV
2021/12/31 20:07:47.656553 [HLS] Starting transcoder for channel 6104 from 192.168.1.200 (encoder=remux, resolution=, deinterlacer=, bitrate=5529)
2021/12/31 20:07:48.935019 [HLS] Probed live stream in 1.277903492s: h264 1920x1080 progressive 5335578bps
2021/12/31 20:07:49.081854 [HLS] Session ch6104-dANY-ip192.168.1.200 started in 3.159186203s
2021/12/31 20:07:52.670978 [HLS] Stopping transcoder session ch6104-dANY-ip192.168.1.200 (out: 0s, finished: false)
2021/12/31 20:07:52.717234 [TNR] Closed connection to TVE-DTV for ch6104 HGTV
2021/12/31 20:09:10.279258 action=authz_retry err=notAuthorized: User must re-authenticate
2021/12/31 20:09:10.279397 [TVE] action=auth mvpd=YouTubeTV requestor=nbcentertainment
2021/12/31 20:09:10.964640 [TVE] action=error_response type=Other error=net::ERR_UNKNOWN_URL_SCHEME url=
2021/12/31 20:09:10.969654 [TVE] action=version product=HeadlessChrome/89.0.4389.114 jsVersion=8.9.255.24 protocol=1.3 revision=@1ea76e193b4fadb723bfea2a19a66c93a1bc0ca6
2021/12/31 20:09:10.971813 [TVE] action=mock
2021/12/31 20:09:10.996429 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=YouTubeTV&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2021/12/31 20:09:10.999447 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2021/12/31 20:09:11.222686 [TVE] action=wait_for_page
2021/12/31 20:09:11.419025 [TVE] action=request type=Document method=POST url=https://youtube.auth-gateway.net/saml/saml2/idp/SSOService.php
2021/12/31 20:09:11.419119 [TVE] action=auth_domain domain=youtube.auth-gateway.net
2021/12/31 20:09:11.565743 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:09:11.805396 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:09:11.876889 [TVE] action=request type=Document method=GET url=https://accounts.google.com/o/oauth2/auth
2021/12/31 20:09:19.635872 [TVE] action=page_ready
2021/12/31 20:09:19.635982 [TVE] action=wait_for_page done=true reason=page_ready
2021/12/31 20:09:19.636030 [TVE] action=fill_form u=
2021/12/31 20:09:19.662876 [TVE] action=tvejs msg="googleLogin"
2021/12/31 20:09:19.750849 [TVE] action=wait_for_auth
2021/12/31 20:09:22.242223 [TVE] action=tvejs msg="googleLoginPassword"
2021/12/31 20:09:43.751796 [TVE] action=auth_timed_out
2021/12/31 20:09:43.751940 [TVE] action=screenshot
2021/12/31 20:09:43.914812 [TVE] action=screenshot size=34131
2021/12/31 20:09:43.915481 [TVE] action=capture_html
2021/12/31 20:09:44.404916 [TVE] action=capture_html size=1849349
2021/12/31 20:09:44.507513 [ERR] Could not start stream for TVE-YouTubeTV ch6003 WAKA: TVE: Cable provider authentication failed
2021/12/31 20:10:18.525971 [TNR] Closed connection to TVE-Verizon for ch6140 ESPN1
2021/12/31 20:10:50.062148 action=authz_retry err=notAuthorized: User must re-authenticate
2021/12/31 20:10:50.062440 [TVE] action=auth mvpd=YouTubeTV requestor=nbcentertainment
2021/12/31 20:10:50.749997 [TVE] action=error_response type=Other error=net::ERR_UNKNOWN_URL_SCHEME url=
2021/12/31 20:10:50.755317 [TVE] action=version product=HeadlessChrome/89.0.4389.114 jsVersion=8.9.255.24 protocol=1.3 revision=@1ea76e193b4fadb723bfea2a19a66c93a1bc0ca6
2021/12/31 20:10:50.759687 [TVE] action=mock
2021/12/31 20:10:50.785976 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=YouTubeTV&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2021/12/31 20:10:50.789341 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2021/12/31 20:10:51.008522 [TVE] action=wait_for_page
2021/12/31 20:10:51.182692 [TVE] action=request type=Document method=POST url=https://youtube.auth-gateway.net/saml/saml2/idp/SSOService.php
2021/12/31 20:10:51.182776 [TVE] action=auth_domain domain=youtube.auth-gateway.net
2021/12/31 20:10:51.372263 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:10:51.587353 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:10:51.659734 [TVE] action=request type=Document method=GET url=https://accounts.google.com/o/oauth2/auth
2021/12/31 20:10:59.377802 [TVE] action=page_ready
2021/12/31 20:10:59.377967 [TVE] action=wait_for_page done=true reason=page_ready
2021/12/31 20:10:59.378043 [TVE] action=fill_form u=
2021/12/31 20:10:59.392978 [TVE] action=tvejs msg="googleLogin"
2021/12/31 20:10:59.474719 [TVE] action=wait_for_auth
2021/12/31 20:11:01.971854 [TVE] action=tvejs msg="googleLoginPassword"
2021/12/31 20:11:23.475904 [TVE] action=auth_timed_out
2021/12/31 20:11:23.476043 [TVE] action=screenshot
2021/12/31 20:11:23.645038 [TVE] action=screenshot size=34131
2021/12/31 20:11:23.645722 [TVE] action=capture_html
2021/12/31 20:11:24.132533 [TVE] action=capture_html size=1849377
2021/12/31 20:11:24.243789 [ERR] Could not start stream for TVE-YouTubeTV ch6073 FNC: TVE: Cable provider authentication failed
2021/12/31 20:27:16.564047 action=authz_retry err=notAuthorized: User must re-authenticate
2021/12/31 20:27:16.564207 [TVE] action=auth mvpd=YouTubeTV requestor=nbcentertainment
2021/12/31 20:27:17.234701 [TVE] action=error_response type=Other error=net::ERR_UNKNOWN_URL_SCHEME url=
2021/12/31 20:27:17.239791 [TVE] action=version product=HeadlessChrome/89.0.4389.114 jsVersion=8.9.255.24 protocol=1.3 revision=@1ea76e193b4fadb723bfea2a19a66c93a1bc0ca6
2021/12/31 20:27:17.247362 [TVE] action=mock
2021/12/31 20:27:17.273964 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=YouTubeTV&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2021/12/31 20:27:17.277307 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2021/12/31 20:27:17.501692 [TVE] action=wait_for_page
2021/12/31 20:27:17.677133 [TVE] action=request type=Document method=POST url=https://youtube.auth-gateway.net/saml/saml2/idp/SSOService.php
2021/12/31 20:27:17.677227 [TVE] action=auth_domain domain=youtube.auth-gateway.net
2021/12/31 20:27:17.882088 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:27:18.080757 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:27:18.152337 [TVE] action=request type=Document method=GET url=https://accounts.google.com/o/oauth2/auth
2021/12/31 20:27:25.884807 [TVE] action=page_ready
2021/12/31 20:27:25.885023 [TVE] action=wait_for_page done=true reason=page_ready
2021/12/31 20:27:25.885180 [TVE] action=fill_form u=
2021/12/31 20:27:25.905950 [TVE] action=tvejs msg="googleLogin"
2021/12/31 20:27:25.984298 [TVE] action=wait_for_auth
2021/12/31 20:27:28.481542 [TVE] action=tvejs msg="googleLoginPassword"
2021/12/31 20:27:48.322036 [TVE] stream timestamps: fnc: start_at=2021-12-31T20:26:48-06:00 current_at=2021-12-31T20:27:08-06:00 end_at=2021-12-31T20:27:16-06:00
2021/12/31 20:27:48.322677 [TNR] Opened connection to TVE-Verizon for ch6073 FNC
2021/12/31 20:27:49.984524 [TVE] action=auth_timed_out
2021/12/31 20:27:49.984604 [TVE] action=screenshot
2021/12/31 20:27:50.136673 [TVE] action=screenshot size=34131
2021/12/31 20:27:50.137347 [TVE] action=capture_html
2021/12/31 20:27:50.624007 [TVE] action=capture_html size=1849000
2021/12/31 20:27:50.717792 [ERR] Could not start stream for TVE-YouTubeTV ch6073 FNC: TVE: Cable provider authentication failed
2021/12/31 20:28:11.331894 action=authz_retry err=notAuthorized: User must re-authenticate
2021/12/31 20:28:11.332069 [TVE] action=auth mvpd=YouTubeTV requestor=nbcentertainment
2021/12/31 20:28:12.007996 [TVE] action=error_response type=Other error=net::ERR_UNKNOWN_URL_SCHEME url=
2021/12/31 20:28:12.013984 [TVE] action=version product=HeadlessChrome/89.0.4389.114 jsVersion=8.9.255.24 protocol=1.3 revision=@1ea76e193b4fadb723bfea2a19a66c93a1bc0ca6
2021/12/31 20:28:12.017992 [TVE] action=mock
2021/12/31 20:28:12.045649 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=YouTubeTV&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2021/12/31 20:28:12.048576 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2021/12/31 20:28:12.295189 [TVE] action=wait_for_page
2021/12/31 20:28:12.479733 [TVE] action=request type=Document method=POST url=https://youtube.auth-gateway.net/saml/saml2/idp/SSOService.php
2021/12/31 20:28:12.479815 [TVE] action=auth_domain domain=youtube.auth-gateway.net
2021/12/31 20:28:12.653498 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:28:12.904401 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2021/12/31 20:28:12.967863 [TVE] action=request type=Document method=GET url=https://accounts.google.com/o/oauth2/auth
2021/12/31 20:28:13.403020 [TNR] Closed connection to TVE-Verizon for ch6073 FNC
2021/12/31 20:28:20.874096 [TVE] action=page_ready
2021/12/31 20:28:20.874297 [TVE] action=wait_for_page done=true reason=page_ready
2021/12/31 20:28:20.874371 [TVE] action=fill_form u=
2021/12/31 20:28:20.891105 [TVE] action=tvejs msg="googleLogin"
2021/12/31 20:28:20.990160 [TVE] action=wait_for_auth
2021/12/31 20:28:23.481193 [TVE] action=tvejs msg="googleLoginPassword"
2021/12/31 20:28:42.298331 [TVE] stream timestamps: espn1: start_at=2021-12-31T20:28:02-06:00 current_at=2021-12-31T20:28:16-06:00 end_at=2021-12-31T20:28:20-06:00
2021/12/31 20:28:42.299012 [TNR] Opened connection to TVE-Verizon for ch6140 ESPN1
2021/12/31 20:28:44.991277 [TVE] action=auth_timed_out
2021/12/31 20:28:44.991440 [TVE] action=screenshot
2021/12/31 20:28:45.151429 [TVE] action=screenshot size=34131
2021/12/31 20:28:45.152111 [TVE] action=capture_html
2021/12/31 20:28:45.693411 [TVE] action=capture_html size=1849386
2021/12/31 20:28:45.797658 [ERR] Could not start stream for TVE-YouTubeTV ch6140 ESPN1: TVE: Cable provider authentication failed
Thank you for all the help for advice! It appears the problem is YouTube TV. When I remove channels such as ESPN and Fox News from YouTube TV and enable them for Verizon they tune instantly. I’m glad I have a back up source. I will prefer all channels from Verizon.
There are a lot of authentication errors which can contribute to latency
Yep completely agree. Was just trying to go down the most probable path
and it needs to be the IP address of the AppleTV, not the IP address of the server... (that took me a while to figure out when I first tried it).
