TV Everywhere Channels
Only supported channels are listed. If it's not listed, it's not supported in Channels. (Some unsupported channels are listed, but that is because at one point they were, and now they no longer are. However, in the case of Viceland, it was never a supported channel.)
Understood. Hopefully then, that sentence can be added to allay any confusion from future customers. It wasn't clear to me and feels a bit counterintuitive to have so much unrestricted access to all of Vice TV's content using the same login workflow I use for all of the other TVE providers, and yet only Vice TV doesn't work with Channels DVR.
(for reference and example, Philo does list Vice as TVE compatible here: https://help.philo.com/tv-everywhere/)
A post was merged into an existing topic: Provider - Xfinity
I just checked Pop in Channels DVR on channel 6096 and it is working fine with my DirecTV credentials.
By the way, very nice list. Thank you for sharing.
Pip was added back in. Originally they were serving malformed audio streams that caused issues. This has since been fixed.
So, I think I'm done with sharing an Xfinity login, any recommendations for a tve provider other than Xfinity? I don't need a ton of channels. The cable news channels, and discovery networks would probably be enough.
I'd say YTTV, but they have issues with logins. Probably Hulu live and Direc tv stream would be your best bet.
