I also got the working on my local Mac, but seems to be having a problem in the docker image. Can anyone confirm?
So just double checking that the mycloud duo have a ARM processor and can’t try this tv everywhere experience
putting credentials for dish and get the following error.
google chrome not finding path to executable, reinstalled and still no joy.
Do you have Chrome installed onto your C:\ drive?
Got it now. Simple fix. Favorites was the issue. Thank you for helping my ignorance. LOL
As far as I know. Its an inexpensive stock dell laptop. I believe it only has one drive.
Please email [email protected] with a screenshot of C:\Program Files (x86)\Google\Chrome\Application open in Explorer.
Thats probably the problem. Its not located there.
So where is it located
Something like User myname appdata local applicationdata, which i cannot open.
I reinstalled chrome and looks like it is loading
@tmm1 - I sent a feedback form last night regarding some missing channels via the Spectrum login but I haven't heard anything back yet. Can you help me with that?
OMG.... This is just getting better and better. So good.
I’m seeing duplicates channels more than just the east and west coast feeds for instance I have 3 TBS channels showing. 1 east coast feed from my prime, 1 east coast feed from TVE-VERIZON and one west coast feed from TVE-Verizon.
Getting a lot of network errors TNT,TBS, ESPN. On Channels, says Tuners not responding. Same channels aren’t working on Fitzy tv, get A network error occurred while communicating with the providers authorization service. Direct to the Network app isn’t working either. Definitely a Spectrum or Network issue, not Channels
I'm missing all the Pac-12 Channels. They were there a few days ago but now they are gone.
https://pac-12.com/networks
I want to say thanks to the Channels support team! I had an issue that was obscure and they pinned it down immediately.
If any of you have two different accounts with your cable provider, you may run into this.
My little vacation home has just cable internet, no TV service. My home has both internet and TV service. I am up at the vacation place and was trying to get TVE to work with my cable provider. Cox cable uses a method of authentication that is based on the account that the internet service is tied to. So when setting up TVE, Cox would only authenticate the TV channel on my plan with no TV service. I had to hook my Channels server up to my cell phone for Internet and then add the Cox service to Channles. It worked perfectly at that point. Just a heads up if you have this situation.
I was told I will need to do this every 30 days, as the authentication token expires every 30 days, but I at least have a working solution!
Having a strange audio issue today with TVE channels only - OTA work fine.
When a TVE channel goes to commercial the audio drops out - usually right around the time that the channel indicates that it is on commercial break. Audio will not play until exiting the show and restarting the stream which usually involves acknowledging the prompt that I am behind the timeline and to exit to guide.
This has happened on multiple ATVs, channels, and after restarting the DVR.
DVR version is v2019.06.21.2348 and client is 3.2.23.
Prior to today there have been 0 issues.
I’m still having issues with streams freezing, primarily during commercial breaks. This has happened on CNBC, Food Network, Cooking Channel and Science Channel, using streams from Xfinity and Philo. Once freezing occurs, the only way of restarting the stream is to exit (I get a warning that I’m behind in the timeline), open a stream on another channel (switch to a different channel), then switch back. I’ve not waited longer than 3-4 minutes after the freezing occurs, so I don’t know if the stream would eventually return on its own or not. DVR is being run on QNAP NAS (2019.06.21.2348), show is being watched on ATV 4K (3.2.23).
I just experienced this too... when this happens, I also get warnings that my buffer is more than xx% full...
2019/06/22 18:36:52 [WRN] Buffer for TVE-Philo ch6110 is more than 50% full (clients=1, len=16809984)
2019/06/22 18:36:52 [WRN] Buffer for TVE-Philo ch6110 is more than 75% full (clients=1, len=25198592)
2019/06/22 18:39:19 [WRN] Buffer for TVE-Philo ch6110 is more than 50% full (clients=1, len=16809984)
2019/06/22 18:39:19 [WRN] Buffer for TVE-Philo ch6110 is more than 75% full (clients=1, len=25198592)
2019/06/22 18:39:20 [WRN] Buffer for TVE-Philo ch6110 is more than 95% full (clients=1, len=31883264)
2019/06/22 18:39:20 [WRN] Buffer for TVE-Philo ch6110 is more than 99% full (clients=1, len=33226752)
2019/06/22 18:39:22 [WRN] Buffer for TVE-Philo ch6110 is more than 50% full (clients=1, len=16809984)
2019/06/22 18:39:22 [WRN] Buffer for TVE-Philo ch6110 is more than 75% full (clients=1, len=25198592)
2019/06/22 18:39:22 [WRN] Buffer for TVE-Philo ch6110 is more than 95% full (clients=1, len=31883264)
2019/06/22 18:39:22 [WRN] Buffer for TVE-Philo ch6110 is more than 99% full (clients=1, len=33226752)
2019/06/22 18:39:25 [WRN] Buffer for TVE-Philo ch6110 is more than 50% full (clients=1, len=16809984)
2019/06/22 18:39:25 [WRN] Buffer for TVE-Philo ch6110 is more than 75% full (clients=1, len=25198592)
2019/06/22 18:39:25 [WRN] Buffer for TVE-Philo ch6110 is more than 95% full (clients=1, len=31883264)
2019/06/22 18:39:25 [WRN] Buffer for TVE-Philo ch6110 is more than 99% full (clients=1, len=33226752)
2019/06/22 18:39:27 [WRN] Buffer for TVE-Philo ch6110 is more than 50% full (clients=1, len=16809984)
2019/06/22 18:39:28 [WRN] Buffer for TVE-Philo ch6110 is more than 75% full (clients=1, len=25198592)
2019/06/22 18:39:28 [WRN] Buffer for TVE-Philo ch6110 is more than 95% full (clients=1, len=31883264)
2019/06/22 18:39:28 [WRN] Buffer for TVE-Philo ch6110 is more than 99% full (clients=1, len=33226752)
