TV Everywhere is not working, do you have a time frame of when this will be corrected?
I believe it’s already been resolved in the latest prerelease version. What issues are you having and what version of the DVR server are you running?
Hello,. I am having the Spectrum issue as well. Keeps saying "Authz Retries Failed". I am using Channels Plus on AppleTV. Connected: 10.0.1.184
You need to update the DVR server software to correct the issue. What version is shown in the DVR server web interface?
Hi there. I am not very tech savvy. Where can I find the DVR server web interface?
You need to know the IP address of the machine hosting the DVR software. In this example I’ll use 192.168.1.3 as the IP address.
You put that into your browser’s address bar and it should display the DVR interface.
Hi Chris, when I Google the IP address, it says:
IP: 2603:6010:6001:e7de:f135:75a0:10de:b005
Would I enter this into the address bar?
Thank you! I got into the interface. Should I just rescan the Spectrum channels?
Yes, if you edit the source and then the channel list you can try scanning the individual channels. You’ll also want to make sure you’re on the latest prerelease version first. If scanning the individual channels doesn’t work, you may have to remove and re-add the source completely.
Thank you! I had to delete and re-add and they are all working now. I appreciate the help!!
