TV Recordings on Beta
I'm using the Beta on Android TV, with the server on a NAS. I have recorded a series of TV shows using the season pass, but when I go watch the first one in the series, I am presented with a long horizontal numbered listing of recorded shows with the first recording (number 1) all the way over on the right hand side of the list. Which means much scrolling to get to it (26 in the list so far).
Am I missing anything here or can this be changed ?
In Settings you can change Airing Order to Oldest First
I'm using Synology NAS and Android TV, I cannot see that setting under 'Settings' anywhere, either client or web app.
Where exactly do you see this and what client / server are you using ?
In the client on Android TV, on the Settings tab, under Library
Ah.. found it... that did it. Thanks
