TV Series Missing Images
Some of those just look like shows that didn't match. Go into them and select "Fix Incorrect Match".
Definitely un-matched based on those names.
The IMDb ids in the folder name are wrecking things. Consider just naming the folder normally with just the name of the show.
realize that after i look at it. running script to remove the imdb stuff.. thanks for the support guys..
now only if we can mulit thread these imports
seems to be outage?
