TV Shows or Movies section focus
While in TV Shows or Movies section of side menu:
After I look into a TV Show (Movie) or finish watching an episode (Movie) I move right or left and the sort changes. It always returns with the focus on sorts and not the show or movie.
Is there a setting I am missing that keeps the focus out of the sort options unless I want to change the sort?
If there is not an option can you make this change? I am always having to move the sort back to recent, move back to the TV Shows then select the TV Show I want to watch. Would make for a better flow.
(fyi..it starts with the focus in the TV Show section when you first enter)
Also, when ever I trash the last episode of a show it stays visible unless you go to the side menu select a different section, go back to the side menu and select the TV Shows. I can not see another way to reset that section. Can you make it so when selecting TV Shows from the side menu it refreshes the shows without having to move to a new section first?
I was waiting for a change hoping someone would bring it up, but I guess not.
Thanks
Which platform is this happening on?
Android TV (Nvidia Shield)
