TV Shows section - recordings not in proper order
I updated the server and app to the latest beta and now in the TV Shows section my recordings are no longer in proper order of newest to oldest when sorted under Recently Updated. In fact they're not in any order at all that I can see. Is there a way to fix this? Thanks!
EDIT: Forgot to add, I'm using Channels Carbon (on my nVidia Shield), maybe that had something to do with it, but I tried reverting back to the native Channels app and it was the same.
Is this just in the web admin or an app too. If app, which platform?
The web admin is correct, it's just the app that is incorrect, in nVidia Shield Pro, running android.
Also, my newest recordings, from today, since the upgrade, are showing up at the top, in proper order, it's just the recordings previous to the upgrade that are messed up. I suppose all my passes will eventually be ordered correctly, so it's not that big a deal.
