TV signal stops and stutters
I experience that when I watch TV remotely, the TV signal stops and stutters. I suspect that this may be due to the Channels server detecting that there is almost no disk space left. It shows that there are around 90 MB available, but this is not a correct reading. I am using about 90% of 1.5 TB, which leaves around 150 GB of free space. I don’t know why the free space is not being detected correctly. Could this be causing the image to freeze every 10 seconds?
Need more details
Client
Results of the bndwidth test to the channels server
What size WAN connection is the server behind
