TVE and Verizon FIOS error
Hi all - recently noticed my TV everywhere channels aren't working. Went to rescan with no luck. I deleted the source and attempted to add a new TVE and received the following error: parse error: expected string near offset 4235 of 'partitionKey'
I've had no luck adding the channels back within TVE. I've attempted individual logins on websites to ensure I still have access (checked the FX channels) and it worked.
Thoughts?
Are you running the latest pre-release version of Channels DVR Server?
Did you run a Troubleshooting check?
Sir I owe you a big thank you! I completely forgot to check for pre-release versions! That appears to have fixed the issue! It's been years since I've had to trouble shoot sources.
When using TVE, you always have to keep Channels up to date (prerelease)
I would probably see if I could get a cablecard from FIOS and grab a HDHR Prime too just in case
