TVE Auth issue possible fix
I just installed the latest beta build 2023.05.06.1857 for a possible fix pertaining to the YTTV auth issue, however I’m still having the same issue. I tried deleting the YTTV source and re-adding it and continue to get the same captcha page. I also tried disabling the option for local TVE channels, then reenabling it and manually doing a scan for the problematic channels. Any thoughts?
Beta install fixed it for me. Thank you!
