I rescanned my TVE channels and now I'm seeing CBS stuck in a cycle with the error "could not find codec parameters".
2021/09/29 10:42:27.703886 [TVE] stream timestamps: cbs: start_at=2021-09-29T10:41:24-07:00 current_at=2021-09-29T10:41:36-07:00 end_at=2021-09-29T10:41:48-07:00
2021/09/29 10:42:27.703969 [TNR] Opened connection to TVE-Fubo for ch6003 WOIO
2021/09/29 10:42:27.709784 [HLS] Starting transcoder for channel 6003 from 192.168.88.148 (encoder=remux, resolution=, deinterlacer=, bitrate=9858)
2021/09/29 10:42:37.965653 [HLS] Probe failed for live stream after 10.252623061s and 0 bytes
2021/09/29 10:42:40.440285 [HLS] Couldn't generate stream playlist for ch6003-dANY-ip192.168.88.148: Timeout waiting for session to start after 8s
2021/09/29 10:42:40.440368 [HLS] Stopping transcoder session ch6003-dANY-ip192.168.88.148 (out: 0s, finished: false)
2021/09/29 10:42:40.441368 [HLS] ffmpeg: ch6003-dANY-ip192.168.88.148-remux: pipe:: could not find codec parameters
2021/09/29 10:42:40.453982 [TNR] Closed connection to TVE-Fubo for ch6003 WOIO
2021/09/29 10:42:41.529190 [ERR] Failed to clean up /mnt/media/Channels/Streaming/ch6003-dANY-ip192.168.88.148-3716639235: unlinkat /mnt/media/Channels/Streaming/ch6003-dANY-ip192.168.88.148-3716639235/cache: directory not empty
2021/09/29 10:42:41.815901 [TVE] stream timestamps: cbs: start_at=2021-09-29T10:41:36-07:00 current_at=2021-09-29T10:41:48-07:00 end_at=2021-09-29T10:42:00-07:00
2021/09/29 10:42:41.815944 [TNR] Opened connection to TVE-Fubo for ch6003 WOIO
2021/09/29 10:42:41.821313 [HLS] Starting transcoder for channel 6003 from 192.168.88.148 (encoder=remux, resolution=, deinterlacer=, bitrate=9858)
2021/09/29 10:42:52.080848 [HLS] Probe failed for live stream after 10.256164898s and 0 bytes
2021/09/29 10:42:57.654210 [HLS] Couldn't generate stream playlist for ch6003-dANY-ip192.168.88.148: Timeout waiting for session to start after 8s
2021/09/29 10:42:57.654319 [HLS] Stopping transcoder session ch6003-dANY-ip192.168.88.148 (out: 0s, finished: false)
2021/09/29 10:42:57.654804 [HLS] ffmpeg: ch6003-dANY-ip192.168.88.148-remux: pipe:: could not find codec parameters
2021/09/29 10:42:57.668873 [TNR] Closed connection to TVE-Fubo for ch6003 WOIO
2021/09/29 10:42:58.749708 [ERR] Failed to clean up /mnt/media/Channels/Streaming/ch6003-dANY-ip192.168.88.148-1894341574: unlinkat /mnt/media/Channels/Streaming/ch6003-dANY-ip192.168.88.148-1894341574/cache: directory not empty
2021/09/29 10:42:59.261790 [TVE] stream timestamps: cbs: start_at=2021-09-29T10:41:54-07:00 current_at=2021-09-29T10:42:06-07:00 end_at=2021-09-29T10:42:18-07:00
2021/09/29 10:42:59.261868 [TNR] Opened connection to TVE-Fubo for ch6003 WOIO
2021/09/29 10:42:59.267457 [HLS] Starting transcoder for channel 6003 from 192.168.88.148 (encoder=remux, resolution=, deinterlacer=, bitrate=9858)
2021/09/29 10:43:00.200798 [HLS] Stopping transcoder session ch6003-dANY-ip192.168.88.148
2021/09/29 10:43:00.204240 [HLS] Probe failed for live stream after 933.212148ms and 0 bytes
2021/09/29 10:43:00.204675 [HLS] ffmpeg: ch6003-dANY-ip192.168.88.148-remux: pipe:: could not find codec parameters
2021/09/29 10:43:00.217272 [TNR] Closed connection to TVE-Fubo for ch6003 WOIO
2021/09/29 10:43:01.313835 [ERR] Failed to clean up /mnt/media/Channels/Streaming/ch6003-dANY-ip192.168.88.148-3751543206: unlinkat /mnt/media/Channels/Streaming/ch6003-dANY-ip192.168.88.148-3751543206/cache: directory not empty
Troubleshooting logs under 0ab27f38-77e8-4354-85ab-2bed2799160f
