Hi Folks:
I'm getting into the inner workings of Channels and am overall liking the service.
One change I've made (thanks to tips on site) is set my TVE source as primary on my DVR Server so that it will prioritize recordings from TVE, while setting my HDHR Prime source as primary on my Apple TV App to prioritize viewing live TV from HDHR (since I only have 3 tuners.)
This works great most of the time....as long as the channels that are both in HDHR and TVE are "matched" so Channels DVR can show multiple sources for the same channel and prioritize the TVE channel for recordings.
However, I seem to have a handful of channels that Channels DVR Server cannot "Match" between HDHR and TVE. Example: NBC, Hallmark, and a few others. The DVR server sees these as separate, different channels on TVE and HDHR even though they are in-fact the same.
What's weird is if I set to record a show on HDHR, it will show the show as being recorded when viewing the TVE channel in the guide. But it won't record it from TVE.
Example:
Hallmark HD is channel 740 on my HDHR. In the "Source" channel list, it shows this in DVR Server as 740 HMKHD -> HALLHD. On TVE's Channel List it shows 6090 HALLMARK -> HALLHD
Both map to "HALLHD". So why doesn't the DVR see these as the same channel? Recordings on this channel will always come from channel 740 instead of 6090. If I view the schedule in the DVR of future recordings, channel 6090 is never listed as an option.
How can I "link" these channels? Same goes for NBC and several others.
Thanks.
