TVE Channels not Working\ HDHR HDHR3-US Issues
Two Things:
  1. I cannot get any TVE channel to work...just throws an error about the URL.
  2. On the DVR Settings page, my Dual HDHR3-US shows 0 channels, but the HDHR Setup scan 66 channels and they show up and are usable in the guide (both on my clients and in my browser, from the DVR settings page). I have tried to re-scan and remove and re-add, with no change.
Logs were submitted.
Do you have guide data set for the HDHR? What error are the TVE channels throwing? The community may be able to help if you provide more details.
Well, Spectrum TVE no longer even showing up as a source on my Clients, although it is still a source on my DVR settings page.
But, I was getting the following kind of message on all TVE channels, when I could select them.
[ERR] Failed to start stream for ch6016: TVE: Post "https://sp.auth.adobe.com/adobe-services/authorize": dial tcp: lookup sp.auth.adobe.com: no such host
[HLS] Couldn't generate stream playlist for ch6016-dANY-ip192.168.67.185: TVE: Post "https://sp.auth.adobe.com/adobe-services/authorize": dial tcp: lookup sp.auth.adobe.com: no such host
After about the 4th/5th restart, everything seems back to normal.
This error means your dns server is malfunctioning
Yep. After I got a chance to poke around, I found I had fat-fingered one of my dns addresses. I have now corrected that. Thanks.
