question - if i view a tve or locast channel while remote, does the stream go straight from the provider to my location, or does everything filter though the Channels DVR first? if it does go through the DVR first, is there transcoding? or is it a direct passthrough?
TVE always streams through the dvr.
It can be pass through or transcoded depending on your client quality setting
